Question about Refrigerators
Whirlpool Gold in-door-ice model GD5RHAXNQ00 not making ice
  • Anonymous Sep 09, 2008
    the ice maker does not make ice. The water does not appear to be frozen in the line.
  • whitetigr Sep 28, 2008
    Same problem here. I checked the coils, and all seems to be fine. When I open the freezer door, the LED on the right side blinks twice, then continues to blink twice in a cycle. When I push on the tab on the left side, the LED on the right does nothing but continue to blink twice in a cycle. Does this mean that the emitter on the left has gone out? What should the LED on the right do when the tab on the left is pushed in?
Just had our repaired for 3rd time in 3 years. Plastic gears on left side are the culprit. On strips and the other breaks.
Posted on Nov 27, 2008
  • 143 Answers
The first symptom of dirty condenser coils is that the ice maker stops getting to zero degrees. (That's what it requires to kick the ice out.) The first thing to check is dirt and dust bunnies on the hot coils.
Put a stick type thermometer in a stick of butter or a pint of ice cream and wait a day to see if the freezer is set getting to zero F.
Posted on Jul 23, 2008
Gd5rhaxnq00
The lights are controlled by door switches and a small circuit board near the compressor=> W10135090 Main Control Board
The control board is quite expensive and if you know someone that can replace circuit board parts it would really pay to have them replace a defective relay, Thanks Sea Breeze
Jan 30, 2013 | Whirlpool Gold White-on-White 21.9 cu. ft....
Light will not come on model#gd5rhaxnq00
Unplug your refrigerator and pry out the door switch and check for continuity. In most cases this can be a defective door switch. Can you test the door switch with an OHM Meter?=> 1118894 Door Switch I am here should you have questions or comments, Thanks Sea Breeze
Jan 10, 2013 | Whirlpool Refrigerators
Ice cube stuck in the ice maker of a RCA Model GD5RHAXNQ00. How can I remove the icemaker?
The ice maker hangs on the wall with three screws. two at the top and one at the bottom. Just loosen these screws and the ice maker will lift off the bracket and you can then reach the wiring harness to unplug it. Here's a DIAGRAM.
Jan 20, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool gold french door model # GI5FSAXBY02. The icemaker stopped making ice -please advise. Thanks. Charles Mara chrlsmara@yahoo.com or cjmara@cox.net
Could you double check your model number. I am unableto pull that model number up. You mentioned that your ice makehas stoppedworking. This could be several things, like water control valve,defective ice maker, defective ice maker thermostat and more. Let me know,Thanks, SeaBreeze b8e6bdd.jpgWHIRLPOOL PRODUCT MANUALS
Sep 26, 2010 | Whirlpool Refrigerators
It just stopped making ice yesterday. A question.
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 11, 2010 | Whirlpool Refrigerators
Whirlpool Gold GD5RHAXNQ00 refrigerator not cooling properly.
It takes time for the temp to adjust(up to 24hrs) If the door is open a lot(looking into the box) or the door gasket is bad this will contribute to your problem. Are you sure the thermometer is good that you are checking the machine with. The thermistor could be bad as well(the control that senses the actual temp
Nov 03, 2009 | Refrigerators
ICE MAkER HANDLE PROBLEM
If your model is the Whirlpool Gold I can possibly help you.
Whirlpool Gold GD5NVAXSY need model number to got to service manual. Sorry, but manual people don't realize how many versions of refrigerators. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Jun 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not getting water, but water to the door dispensor ok
The fill solenoid for the ice maker is not working. Replace it and you are good to go.
Sep 24, 2017 | Whirlpool GD5SHAX Side by Side...
Whirlpool gold gd5rhaxnq00
Couple of reasons
a) Excess humidity in the refrigerator due uncovered food items.
B) freezer door not closing fully( look for any visible damage or hardness of the seal. The seal is made of multiple layers so even a few cracked edges will cause leakage.
c) the returning air if not circulated properly by blower which also gas a heating coil for humidification could have failed causing formation of ice.................sodeep
May 17, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker will not dispense the ice
When you press the lever to dispense the ice, there are multiple switches being activated. Chances are, the one that moves the motor to turn out the ice is bad. Or that motor itself is bad.
Mar 13, 2009 | Whirlpool GS6SHAXLB / GS6SHAXLL /...
Refrigerators Logo
420 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
