Question about Dishwashers
Brand new high end electrolux dishwasher perfomring horribly - likely due to hard water issue. Cloudy glass and resident left on dishes. Have the rinse agent set at max and hot water is at 150F...is the only solution a water softener??
  • Pam Parsons
    Pam Parsons Jul 23, 2008
    We weren't aware of the softener - where do you put salt in?
    thanks
    President:
  • 1,462 Answers
Dishwashers have a water softener incorporated but this needs salt to regenerate. have you put salt in?
Posted on Jul 23, 2008
  • douglas smith Jul 23, 2008
    usually a container on the bottom inside - has a screw cap about 3ins diameter. you need dishwasher salt mind
Dishwasher dishes cloudy and makes loud buzzing soundf
I am not sure about the buzzing but cloudy dishes is caused by
hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jan 03, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Suddenly my asko dishwasher is not cleaning my dishes effectivelyl-- there are cloudy smears all over my glass ware & cutlery-- I use a rinsing agent, but it makes it all worse.
soak the cloudy glass ware in white vinegar for at least 5 minutes. If you can remove it, it could be hard water. You need to adjust your detergent amount. Have you changed detergents ? If so use a high quality brand.
If vinegar doesn't remove the smears, it is probably etching that is caused by hard water, too hot water or prerinsing
Sep 17, 2010 | Asko Dishwashers
CLOUDY DISHES IN DISHWASHER SOMETIMES THE DISHES COME OUT CLOUDY
modern day dishwasher use less water than the older ones so you have to use less soap a lot less only 2 tablespoons but you also have to use rinse aid with the very little soap the cloudy residue on the dishes is left over soap
Apr 04, 2010 | Maytag MDB9600A Jetclean II Built-in...
Food left on dishes, and glasses are very cloudy. We use rince aid, and have tried several detergents. Water temperature has been turned up twice.
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 01, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Cloudy dishes
Sep 22, 2009 | Maytag MDB9100A Dishwasher
My glasses are cloudy and some of the dishes looks like sand or partials on them after a 2hour cycle. I also use jet dry .
Some states such as Califoria, have hard water. Since you did not specify waht state you reside, I am going to list some hints with hard water issues.
a) If you hand wash the glasses (preferanly soak them in vinegar) and the glasses don't come clean, then you have a high temperature issue.
b. If the glasses come clean, then one of the following issues are occuring.
1. Check your spray arms (the bars that rotate) for any blockage in the holes.
2. Check for water hardness i.e. test strips -or take a sampe of water to your local water district for analysis
3. I f hard water is present then increase the amount of detergent. The phosphorous content should be 6 or better. (cascade powder with bleach)
4) Check the dial setting on your rinse aid dispensor-- if it's set too high, this will cause cloudiness on your glasses. The setting should be between "2" and "3"
5) Is the water heating during the wash cycle? Run the diswasher on normal cycle , then after 25 min, open the door and determine if you feel stem on your face. If you do, more than likely the unit is heating properly
6) What is the temp of the hot water coming out of the kitchen tap? It should be 140 degrees.
7) Purchase Dishwasher Magic (Ace hardware, TRue Value) --it comes in a plastic bottle that has a wax coating on the opening ( after you remove the cap) It's a liquid cleaner and works great. This will flush your system
Hope this helps!!
Affordable Appliance Repair
Serving South Orange County, CA.
Jul 08, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
Cloudy Glasses
The problem is hard water and jet dry will not solve that. There is a new product out called The Dishwasher Filtration System. It filters the water going into your dishwasher leaving your dishes spot free with every load. It is very affordable and fits right under the sink. You will be amazed how sparkling your dishes look just after one load. You will love this product. Get it at www.dishwasherfilter.com.
Jun 01, 2009 | Dishwashers
Cloudy glasses
the problem is hard water. there is new product at www.dishwasherfilter.com that is guaranteed to solve this. it filters the water going into your dishwasher reducing the hard minerals and leaving your dishes spot free everytime. you will be amazed. it is very affordable. www.dishwasherfilter.com
Mar 28, 2009 | KitchenAid Dishwashers
Cloudy glasses
Try Calgone, it usually takes care of those types of problems.
Mar 14, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwashers Logo
156 people viewed this question
Top Dishwashers Experts
