Hp 7401 all in one will not send a fax it makes a wizzzzzing sound and than reads scanner failure. this machine is a little over 2 years old and seldem used.
    Guru:
  • 1,049 Answers
If the fax is seldom used, the conditioning of the line could be different or the modem damaged.
Pick up the phone on the unit and see if you can hear a dial-tone, commonly when surges come in through the phone lines and damage the modem component of the printer it can cause this issue and trying to place a call from the device can be a good test.
However, if you can hear the dial-tone using the phone and can call out on your device, it is probably not the modem and is related instead to the line itself.
If your on a company network or have DSL at home remember that faxes typically need dedicated analog lines and that DSL service, IP phones, or digital phone systems will often cause the modem to malfunction.
Posted on Jul 23, 2008
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
Printer scanner failure
The motor that pushes the scanner for faxes and scanner has finally given up (or a gear broke)... Most only have a 2 year lifecycle. HP has designed it that way. I used to work for HP All in One.. whenever someone would call in for that issues, the document we used ALWAYS (for all units) said "replace" :(
Aug 11, 2009 | HP PSC 2175 All-In-One InkJet Printer
HP Officejet Pro L7680 All in One - cannot send faxes - keeps jamming and says "scanner failure unable to scan copy or send a fax. Turn the power off and on and try again" I have done this several times...
The scanner is the problem, the scanner is the real bright light that comes on to scan the orginal document. Does your Scanner lamp come on? mite be burned out? stating scanner failure, doses your scanner move when it scannes the document? Motor or cicruit board that control scanner mite be bad, check the scanner "Home " position sensor maybe the scanner board and main board don't know where the scanner is phyiscal when it goes thur its routine.
Jul 08, 2009 | Office Equipment & Supplies
I CAN`T SEND A FAX
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
Our HP Officejet 5600 won't receive faxes.
Here is the answer to your question.
Error code 244 can mean any of the following things: :
1. You or the person sending the fax pressed the STOP key , causing the session to stop before completion.
2. The fax machine on the other end determined that there is an incompatibility with your machine and the one you are sending to and stopped the fax session.
To fix this you can try the following things. Try them one at a time, and if they don't work, place them back the way they where before you changed it.
  • Make sure the fax machine you are sending to can accept and use polling.
  • Select a slower "receive" speed.
  • Enable or disable the ECM setting.
Error Code: 232
1. Can mean that a communication failure has happened between the two machines.
2. It may also mean that the user of the FAX machine you are sending to has pressed the STOP key
3. If call waiting is enabled, it may cause this error. Disable call waiting on your phone line, if you have a fax machine connected to it. The click or beep on the line that indicates you have a incoming call, can STOP a fax session.
4. Another cause of this error code is that the power was interrupted to the machine you are attempting to send a fax to.
Things you can do to solve this problem: Try them one at a time, and if they don't work, place them back the way they where before you changed it.
  • Try disableing ECM. However, this may reduce the quality of your faxes.
  • Ask the person you are sending the fax to to set the machine to receive at a slower speed.
  • Try the fax again at a different time, incase it is a problem with the phone line.
  • If you phone lines are old, or there is static on the line it may cause trouble sending a fax.If this is the case you will need to contact your local phone company or whoever is responsible for servicing your phone lines.
Jun 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp officejet 5610 Wont scan . Print. Copy
your printer is dead and is uneconomical to repair. sorry
Jan 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Whizzzzzing sound and will not send fax.
The problem is the power supply try to plug to different outlet and then send a fax if it fails then its a power supply fault please change it.............
May 27, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP d135
Try posting your question in the correct section. This category is for Epson CX11 machines
Dec 04, 2007 | Epson ACULASER CX11NF All-In-One Printer
263 people viewed this question
jasbo
jasbo
