Question about Sharp Televison & Video
Sharp TU-R160H digital recorder looses picture and sound, basically whole signal. the only way to get it back again is to switch off and on but means i have t6o reset everything. this is my second machine as the first one did the same and i had it replaced. can you help please?
    Master:
  • 848 Answers
Just check the power supply given to dvd player it may be too high or too low also clean the lens properly ...........
Posted on Jul 23, 2008
  • Sharp Master
  • 19,396 Answers
There is no much you can do, if it happens after a while it can be a overheating problem
  • Ginko
    Ginko Jul 23, 2008
    To find out if it is overheating a repairman can run the dvd with cover open and a fan blowing on it. If it stays on it is the termic sensor or a wizard repaiman can add a more powerful fan.
    Other possible cause is a bad firmware, in this case you will have to send it to sharp as firmware upgrade is not available for users.
    Check if it is under guaranty, if you had it replaced get a new one, sometimes retailers get lots with more than one machine with same fault.
    Get it replaced.
Tu-r160h Factory Reset
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Nov 06, 2012 | Cell Phones
My NIkon D3100 does not make a sound anymore when he's ready to take a picture although in the menu the signal is on. When I change the signal from on to off and back again, he does give that sig
See if you can reset the electronics and restore the unit to factory defaults. If no result and if Nikon does not have a hidden code to fix situation you will either have to live with the situation, replace the camera, fix the camera (not cost effective.) Your choice.
Sep 03, 2017 | Nikon D3100 Digital Camera
SHARP LC-37SH20U GREEN LIGHT BLINKING BLANK SCREEN NO SOUND HAD A POWER OUTAGE & NOW IT WILL NOT TURN OFF UNLESS YOU UNPLUG FROM POWER SOURCE & IT WILL NOT GIVE PICTURE ABOUT 2 YEARS OLD CALLED...
The tv Tuner signal board is it shorted and the caused,that the board where ur tv signal cable wire plug in for tv broadcasting air tv stations.This tv Tuner signal board must be replaced,u can do it if u some basic mechanicals skills like take things aparts and putting it back together again?Yes?U tries websites like Shopjimmy.com,Ebay.com to buy a whole tv refurbish tv Tuner signal board for the replacement.Or must get a priced quote by tvs repair shops,replaced an repair by thems.
Jul 26, 2011 | Sharp LC37SH20U 37 in. LCD Television
A Sharp LCDTV that, at first, had the screen turn white with sound then no sound or visuals other than the white screen. Suspicions that linked the problem to a game console were erased when it did the...
Tries tv unplug,replug it back like about an hour later.The tv will be resetting itself back to the factory original setting.The tv now,might be working.If not,the tv still have the same problems.This tv problems i fixed it before,the tv main Tunner signal board it is the causes and problems.It is a dying output board.The tv main Tuner signal board,that the board where all the external devices and the tv incomming broscasting signal cable wire plug into it.U can do some basic mechanical works like take things aparts and putting it back togeether again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole tv main Tuner signal board for the replacement.
Apr 30, 2011 | Televison & Video
Digital tv -analogue vcr records and time records and plays back only with the picture on. It will not record with picture on standby
Of course it won't record if the TV is in standby as there is no signal. If you wish to record TV programmes without having the TV switched on, you need a freeview or freesat box for your Video Recorder.
Hope this helps.
Nov 15, 2010 | Hitachi C21FL20F TV
How do i delete unwanted tv channelsfrom my sharp model tu-tv322h digital tv recorder
I am not sure what features are on this model, but you may have a favotites setting to mark the favourite channels and skip the rest.
Apr 08, 2010 | Sharp TUTV322H
I can't view advanced options. The date stamp on/off button has vanished. My Polaroid i634 has been restored to original settings, and now iconc/buttons are no longer there. How do I turn the date stamp...
I turned it on, and pressed the video/live recording button that was next to the trash/delete button. That is a whole other menu. After pressing the video/live recording button, I just went up to the first selection, "Program." That takes it off the basic/Q-Mode, which opens additonal options, like ISO and Date Stamp on/off. So basically:
1) Turn on, having the camera on picture taking mode, not review picture mode.
2) Press Video/Live Recording button.
3) Go to first option, called "Program"
4) In this mode, many other options are available, and there will be smaller icons.
Jan 02, 2010 | Polaroid i634 Digital Camera
37 inch Sharp Aquos. "Failed to receive Broadcast [E202]"
This is basically a message for no signal on the tv, make sure the tv itself is on the correct input for the type of cable used. The inputs are labled by numbers on the back of the tv. The input can be changed by the button on the side panel of the tv.
Aug 13, 2008 | Sharp Aqous LC-26D5U Television
How tu use video recording..
The picture that I posted shows a TZ3 mode dial. I added a blue arrow to point out an icon on the mode dial.
1. Turn the mode dial on the camera so this icon is selected.
2. Switch on the camera.
3. Aim the camera at your subject, press the shutter button halfway to focus, then press it fully to begin the video. (Just as you would take a picture.)
4. To stop taking video, press the shutter button fully again.
~When a video starts being taken, its current length will appear on the camera's LCD screen.
~Videos take up more space on the memory card than do pictures.
~If an SD memory card becomes full while recording, then the video will stop automatically.
~Videos can be played back on the camera's "PLAYBACK" mode. They can also be viewed on a TV or downloaded to a computer.
Jul 23, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Tunner? Picture whites out
Is this when you are watching a DVD, or Tape, or when watching TV using the Combo's tuner? The effect you describe is caused by the video signal losing its DC level.
Hope Ya Fix it.
Jan 08, 2008 | JVC DR-MV1SUS DVD Recorder / VCR Combo
Televison & Video Logo
127 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
