We recently enstalled a Wireless-G Broadband Router (WRT54G2). Everything is fine trying to go from Desktop to Toshiba Laptop. I am on Comcast and can't get on line with the laptop. Our laptop keeps defaulting to Ihug, a New Zealand ISP. Since we just moved from New Zealand. Can you help us. Josie and Jim
  • Hollyecho Montgomery
    Hollyecho Montgomery May 11, 2010
    This is a basic tutorial for using and connecting to any WiFi Network....
    1. Before you attempt to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP key are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi providers have this information on their web site or when you purchase access you will be provided the information.
    2. Ensure you have a firewall program installed and running. This will protect your data.
    3. Start up your laptop and once booted, look for the Wi-Fi network icon in the bottom right of the screen.
    4. Click on the Wifi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click on the Properties tab.
    5. The next window will show the type of networking card installed. Click on the Wireless Networks tab.
    Sergeant:
  • 313 Answers
6. Once the Wireless Network Connection Properties window is open you will have two options depending on how you set up your laptop.
· If you do not see any networks listed in Preferred or Available networks, you will have to manually add the SSID. Click on Add. You will have to enter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available networks box.
· If you see the correct SSID showing in the Available Networks, then you need to click on Configure in order to enter the WEP key if that is required.
2. In the next window, enter the SSID for the Wi-Fi network you want to access. Make sure you do not have CAPS lock or NUM lock while entering the information. If a network key is required, click on "Data Encryption and then enter the Network key you have been provided with. Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly a message will pop up and you will need to re-enter the key.
3. Next go to Start - and where it says Connect To click on that and you should see choices like in the graphic below. Click on Wireless Network Connection and it should work.
There are occasions when the connection doesn't work, in these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall program disabled, you change your settings. If your firewall program is not the problem check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
Posted on Jul 23, 2008
    Hollyecho Montgomery Jul 23, 2008
    (first part of post that didn't get posted)
We have BT broadband. When we occasionally have to reset the router, everything except the 2 Dell Dimension 5150 desktops works via wireless. They refuse to reconnect. All the other Desktops / laptops work...
Not sure exactly what your hardware setup is, but I would reboot the broadband router, then reboot the wireless router. Everything should come up clean, but give it at least 5 min. To help connect after reboots, you can choose "repair" from the wireless icon in the system tray (XP?) or renew your IP address. Start --> Run... and type ipconfig /renew
Hope this helps!
If so, please leave a rating!
Mar 11, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Cant connect to internet through laptop
you may need to get a router or they have a wireless hot spot finder you can buy try that
Apr 21, 2009 | Computers & Internet
Comcast says my old WRK54G router is defective. Should I replace it with WRT54GS (Walmart $55) or WRT54G2 (Staples $64). (2 home PC's & occasionally laptop-pretty heavy internet...
Since your WRK54G is already bad, I will advice you to get this WRT54GS router because i can tell you that it work fine and the connection is much faster compare to this WRT54G2 and WRT54GS is pretty much stable compare to the WRT54G2 since I have work for Linksys for almost 3 years...
DOn't forget to rate the solution FIXYA thank you...........
Oct 17, 2008 | Computers & Internet
I have recently moved house from a virgin broadband connection taking my router and lap top with me. My new home has existing virgin broadband. Having plugged everything in as should be my laptop finds the...
Try reseating te broadband connection to the router.
It soundslike your router works if it connects to your laptop with a great signal. But its not sending any information through.
Try reseating. if it does not work. you might need to do a fresh reinstall of the router. Usually the broadband connections attach itself to a mac address of a network card. If you recently put a new router the network cards MAC address is different and it might not send signals through. like for me for cable i have the same issue.
Try this let me know how it does. If any problems please let me know.
I hope this helps
Please Rate.
Sep 18, 2008 | Belkin Computers & Internet
Trying to set up wireless from desktop (Main ethernet computer) to Laptop @ home. Have cable modem (comcast) connected to desktop (main ethernet plugged computer)Belkin Wireless Router G ethernet is hooked...
Check that the wireless drivers are installed properly on both your laptop and desktop. THe certificate error is because your laptop does not "trust" your computer. Under network conections click add a connection ec, and when you try to conect, microsoft should ask you weva to trust the connections from computer to computer that should do it :D
Sep 07, 2008 | Belkin Computers & Internet
Hello, I have a RCA digital broadband model #DHG535-2 modem from comcast, i recently purchased a Linksys wireless-g broadband router model #WRT54G2V1 The problem I am having is connecting from my laptop...
If your trying to connect wirelessly with your laptop make sure that you have the following information of the router;
1. Wireless network name or SSID
2. Wireless security settings; WEP 64/128 bit ot WPA
If your not familiar with the settings then you may need to access the setup page of your wireless router. Hardwire the laptop to the router or if you have a main computer that is already connected with an ethernet cable, open Internet Explorer or Mozilla Firefox or any web browser you are currently using. On the address bar type http://192.168.1.1 (router's default IP), then you will receive a pop up asking for a username and a password, there is no username and for the password type "admin" then click the Wireless tab on the router and check the basic wireless settings, if your not comportable with the settings then change the following; SSID - use a name that is easy to remember, Channel - 1,6, 11 is ideal, then for the Wireless Security choose WPA Personal and enter a 8 digit WPA Passphrase(pasword), remember to click save settings every tab that yuo go to or else the settings will na take effect. Then check if the laptop will detect the signal of the router and when it prompts you for a password or network key, just enter the 8 digit code that you have configured earlier.
If you have further questions regarding the setup of the router just post a reply and I'll to give you a response if my sched will allow me.
Hope this will atleast provide you with some idea in setting the router properly for your laptop.
Regards,
Sep 02, 2008 | Computers & Internet
I submitted the wrong email when I first came here to send you the problem I'm having setting up my broadband router. My email address is willow70815@hotmail.com. I'm hoping that you can help me solve...
the blue and jellow ethernet cord is the same thing.
Make sure you have wireless switch on (enabled) on the laptop
If you have wireless enabled, it should say one or more wireless networks detected in windows xp. Also, if you have a certain router, you might need a code to unlock it so you can use it.
Jul 30, 2008 | Computers & Internet
I have a Comcast cable modem (Arriss) with a Linksys router attached to a Dell PC desktop in one room. In an other room is a Dell PC laptop with a Linksys Wireless -G Notebook adapter card inserted. I am...
you will have to access the router by the ip address.
(192.168.??.??)once you log in, user name blank and password admin. you will have to set up wireless security. there are several ways and each that is selected has a brief tutorial.
Sometimes, people who are gamers or use Ipods, leave the router unsecure but limit the wireless access by mac address or by ip address so only those wireless devices gain access.
Apr 11, 2008 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
