Question about Samsung SCX 4521F All-In-One Laser Printer
Jamming, roller lines and loud fan
My 4521 is only 2 years old and I print about 200 pages per week. There are roller marks on my faxes, it jams frequently (every page we printed yesterday) and the fan is abnormally louder than before recently... is there an easy way to crack open the printer and clean the fan?
    Guru:
  • 1,049 Answers
You'll want to purchase the service manual for this printer if you do not already have one. Obviously the fan is the most annoying problem. But the jamming, the roller marks, and other issues would indicate that the entire printer is probably needing to be cleaned out and that the rollers may even need to be reconditioned or replaced.
Posted on Jul 23, 2008
Why is my fax machine jamming all the time
Dear
If paper jam always,check the thermal ribbon correctly installed (the ink coating face upward and should above the print head)
If document jam always, check the ADF roller (white roller clean it)
Thanks.
Feb 26, 2015 | Panasonic KX FP215 - Fax / copier - B/W -...
HP P3005d won't pick up paper unless tray is mostly full (phantom paper jam)
The problem could be related to the age of the machine. No matter what fix you try, it won't be permanent.
Apr 11, 2014 | HP LaserJet P3005n Printer
Paper jams brother mfc 7420
Paper Jams are routinely caused by bad roller in the printer. The Heat of laser printers can render these rubber roller pretty useless in a couple of years or less if you print often. If you have recently replaced the drum (according to the recommended print output number), Then If an $80 dollar roller + labor is worth it to you, go for it, otherwise buy a new printer and Brother gives the best ink value per page. hope this helps.
Jan 28, 2013 | Brother MFC 7420 All-In-One Laser Printer
I have a Brother 5370DWT. I replaced the drum about 5 weeks ago and just yesterday I started having jamming issues. Every couple of pages the printer is jamming. I have to pull a page from the drum and...
I have had the same problem on these machines, try cleaning the paper pickup rollers, ive also found that some remanufactured cartridges causes this problem, I dont know how or why but they do.
Dec 09, 2010 | Brother HL-5370DWT Laser Printer
Paper jam in Panasonic KX-
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
My laserjet 1020 develops a paper jam after printing the first page of a multipage print instruction .I have deleted the printer and re-installed it including all drivers but problem still...
Reinstalling the printer is related the Software.
If the paper gets physically jammed than its the driver setting issue or hardware issue.
Check if two sheets get jammed or only one sheet.
If it is two sheets than printer is picking up multiple sheets and paper gets jammed.
If the printer is jamming a single sheet than remove the Tray and look there is rubber roller inside if there are marks or lines on that rubber roller or if the roller roller is worn out than that rubber roller called as paper pickup roller need to be replaced.
If that looks fine than try to priny using manual feed and if the problem persists from manual feed too than try another toner cartridge
If the problem is not from Manual feed Tray that Replace the main Tray with known good Tray and check if the issue resolved.
Jul 01, 2009 | HP LaserJet 1010 Printer
Hp officejet 5610 All-in-One ADF automatice document feeder jams
where is it jamming. Clean the rollers with a toothbrush and water, horizontally.
Apr 11, 2009 | HP Officejet 5610 All-In-One InkJet...
Constant Paper Jam
I have the accordion paper jam problem as well, almost all the printout got jammed. So I opened the back panel and unscrew 2 screws and take out the part with the small plastic roller and clean those. Then I also see a rubber roller on the ceiling of that area and cleaned and rubbed them with a damp cloth and rolled them several times. Now it's been 2 weeks of jam free printing! Back to being happy customer...
Jul 21, 2008 | Brother MFC-7820N Laser Printer
HP 6210 using double paper?
Try cleaning the rollers (especially in the back door). It stopped mine from jamming. Hope it will stop the double paper thing!
Apr 15, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Samsung SCX 4521F All-In-One Laser Printer Logo
108 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
