Question about Canon ImageRUNNER 330s Copier
Canon Error code E803
When I try to fax or copy the machine stops and flashes "E803" can someone tell me what this code stands for?
  • Anonymous Feb 05, 2009
    I have the same problem. It powers up fine, but when I try to copy, I get the E803 error code. If it is the scanner lamp, how do I fix it?
  • eric moirez May 11, 2010
    1. e803 is a problem with the scanning lamp. Does the lamp light up when you power on or does it go right in to error code?
Posted on Oct 10, 2009
Thank you very much, that was the problem.
Posted on Jul 28, 2008
E803
i have ir400 machine but not touch the sharpnees button
Jan 04, 2014 | Canon imageRUNNER 400S Copier
Error light is flashing, can't figure out why, no code
I know this was posted a long time ago but for what it's worth. The error codes are probably turned off. I can tell you how to turn on the error codes if this is still a problem. please let me know.
Dec 05, 2013 | Canon LaserCLASS Fax 710 Printer
IR 400 MACHINE ERROR CODE IS E803-000
E 803 Codes are Coming IN Cannon IR 400 Copier Machines.Need the solution For How to olve it?
Oct 21, 2010 | Canon imageRUNNER 400S Copier
Problems with Canon 7500 Laser Class fax
I have Canon 7000 Laser with Error message #330 which said
SET DOCUMENT??? HELP?
Dec 03, 2008 | Canon LaserCLASS 7500 Plain Paper Fax
Hi, I have a Brother MFC-210C that keeps telling me its unable to clean, I followed the user manual but it keeps displying the same message, what do I do now? please help
For Brother MFC210C Printer Fax Copy Scan
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode).( "The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.") Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Carry on printing !!
Dec 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
Mp830 fax problem
Got an answer from Canon NZ:
1. Press the red Stop/Reset button and keep it pressed.
2. The 'Alarm' light will flash - count 12 flashes.
3. The screen on the Canon will show 'SERVICE MODE' and something #1.
4. Press the right arrow key twice to bring up FAX TYPE #3.
5. Press OK to check the country - mine showed Australia when it should have been New Zealand. Scrolling with the arrow keys shows the countries available for your machine.
Jun 19, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Ploblem
the error code you are refering to is not an inverted 83 is in actuality an E803 flashed by an E8 followed by an 03.Basically your 24V dc is either being shorted somwhere internally or the DC controller or composite PCB needs to be replaced in either case the cost associated with replacing either curcuit board would far exceed the value of the copier.
Nov 27, 2007 | Canon NP 7130 Black and White Copier
Fax machine won't copy or send a fax.
IT MAY BE A CIS BUT  I WOULD TRY A SYSTEM CLEAR FIRST
FUNCTION *2864 IN SEQ. THEN 01
Sep 30, 2007 | Brother IntelliFAX 4100 Laser Fax
1,846 people viewed this question
old marine
old marine
