Question about Philips Magnavox 51MP392H Rear Projection Television
Alignment I have a 51" widescreen Magnavox projection type tv. I turned it on last month and noticed that the alignment had gotten severely off. It is not off on just an up/down, left/right basis. The colors are bending/bowing out from the middle towards the top and bottom. The packaged remote did not help much in rectifying the problem. Is there anything else I can try, b/c the serviceman did not help at all.
  • artist_1986 Jul 28, 2008
    Thanks for the help. I will see what I can do and will post the results when I know them.
    Genius:
  • 1,139 Answers
Hello artist_1986,
It sounds like your convergence amplifiers have failed, and they need to be replaced. This is a common problem, however it could be as simple as replacing the two STK392-1XX amplifiers and the biasing resistors or as complex as replacing them and the convergence coils (I have seen and done both). There are many articles on the Internet on how to do this yourself, but I do not recommend them even though many of them actually work. I don't recommend them because they have very little to do with troubleshooting a problem rather then just replacing what you think is bad (shotgunning). I do however suggest having a qualified TV service person check the convergence circuit and see if it has failed. The charge for this is not expensive and you get a parts and labor guarantee if the parts fail in 30 days. I think this is the best course, however, if you still feel the need to fix this yourself do a search in fixya for convergence amp replacement and it will point you to a number of helpful instructions.
I wish you well,
Thank you,
Shuttle83
Posted on Jul 27, 2008
  • Henry McKelvey
    Henry McKelvey Jul 28, 2008
    Hello artist_1986,
    Here are some generick instructions for removing and installing the convergence amplifiers.
    I hope these help you in solving your problem.
    1) Get the schematic/service manual for this TV (You will need it because it contains the part numbers and component values you will need for replacement)
    2) On the schematic/service manual locate the convergence amplifiers (STK392-110, 120, 150) and the biasing resistors (Write the resistor values down from the schematic)
    3) Unplug the TV and remove the rear cover to expose the electronic circuitry.
    4) Using the schematic/service manual find the physical location of the two convergence amplifiers (Usually attached to a big metal silver in color heat sink) (Basically it will look like two big black six sided flat modules with a lot of pins on the bottom (18-22 to be exact)).
    5) After finding the heat sink and amplifiers remove the screws or the tension bar holding the amplifiers in place.
    6) Using a soldering iron and a de-soldering device (either a de-soldering pump or de-soldering wick) remove the solder from the pins of the amplifiers and biasing resistors that protrude from the solder side of the circuit board. (Take into mind that you may have to remove the board in order to do this, use the instructions in the schematic/service manual to do this, and make sure you mark everything you remove to make sure you have a guide as to how to put it back)
    7) After removing the solder from the pins off the amplifiers and the biasing resistors, remove the resistors making a list of the value, part number, and location on the board (all of this should be in the schematic/service manual). Then remove the two convergence amplifier modules taking care so as not to damage the circuit board. NOTE: The heat sink compound (the white goopy stuff) may have hardened and caused the module to stick to the heat sink, you will have to gently pry the module away from the heat sink, I have used a light application of isopropyl alcohol to dissolve the heat sink paste.
    8) Once the modules are loose from the heat sink, you can gradually remove them from the circuit board.
    9) Clean the heat sink off by using the alcohol and a heavy paper towel (remove all of the heat sink paste, and yes this is messy)
    At this point you have removed the two convergence amplifier modules and the biasing resistors and cleaned the heat sink.
    Now you will have to use your schematic/service manual to find the part locations, values and numbers you will need to replace the old parts I suggest replacing the biasing resistors first.
    1) Sort out the resistors you will need and as stated in the schematic/service manual and replace them according to the schematic/service manual locations and part numbers.
    2) Solder the components (resistors) in place making sure not to short out anything in the process.
    3) Apply heat sink paste to the metal side of the modules one at a time and the put the modules into the circuit board lining up the screw holes of the modules with the screw holes in the heat sink, use the removed screws or tension bar to hold the modules down once in place in the circuit board and on the heat sink.
    4) Solder the pins of both amplifier modules to the circuit board, taking care not to short out anything.
    5) Reinstall the board to the TV, reconnect all cables removed (DOUBLE CHECK EVERYTHING)
    If all went well the convergence amps should be working, and you will need to realign the convergence of your TV, I suggest using the AUTO Convergence feature of your TV (Use the instructions in the schematic/service manual).
    All should be good now.
    Now these instructions are generic in nature but can be use for a number of Models of Projection TVs.
I have a PT-53WX53 CRT rear projection widescreen tv. The guns off and the red and blue are no longer aligned. I tried to adjust with the 9 point convergence correction but it only helped a bit. I know...
Convergence + - don't alignment or some mis alignment anywhere in the picture.The R,G,B colors lines don't move any of the color line.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergencce board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 27, 2010 | Televison & Video
I was given a big screen Magnavox TV model #38346033. I don't know how to clean the screen. Also the screen has red, green and blue that needs to converge and I don't know how. I don't have the remote or...
Hello linda, hi, I dont think the remote or manual can help the color issue problem, the tv needs to be looked at by a qualified technician. If the TV is a tube type, there are magnets on the neck that needs alignment, this alignment is done while the TV is ON. so high voltage risk are likely. keep out and call service.
Jun 15, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 51 mp392H, red is out, what can we do?
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Philips Magnavox 51MP392H Rear Projection...
Toshiba projection tv, blue color out of alignment
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 26, 2010 | Sony KP-51WS510 51" Rear Projection...
Red Alignment problem on a Hitachi 51inch rear projection tv
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2009 | Hitachi 51F500 51" Rear Projection...
Magnavox 52" widescreen 2003... When you turn it on it takes abou
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Screen shrinks and expands - may or may not correct itself after the TV warms up.
After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Jan 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture getting darker
first thing i would look at is it is probabily dust on the lences and miror, you need to take the screws out all the way arount the screen from the back, then lean the screen out tward you from the front, do this while the tv is on, you will be able to see the dust alot better, take a soft cloth and glass cleaner and clean little miror, and lences
Jan 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
Sony kp53hs30 screen is curved at top/bottom when in widescreen
on the sony we have to make the convergence alignments on all the modes, only a qualify tech can do that
Dec 17, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51WS510 51 burn in?
You could have leaky capacitors causing this.
Sep 03, 2008 | Sony KP-51WS510 51" Rear Projection...
BIG TROUBLE with my 52" Phillips Magnavox Rear Projection Tv, HELP!!
It sounds like the 3 "GUNS" are not aligned.
One the controls at the bottom, left hand side You will see an arrow pointing to the first 2 on the left.
That will allow you to scroll down the list of options until you see....CONVERGANCE!
make the red gun center by using the up/down arrows on right. Then add the next 2 until you see a white X or cross.
Thats it!
Mike
Jul 16, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
