Question about Dell 922 All-In-One InkJet Printer
Printer is printing every line two times and is faint
Printer needed new cartridges. Bought them new and put them in. Ran the alignment test and the printer says to remove tape from cartridges but, I have already done that. It is printing every line two time with missing letters and is very light. Cleaned the heads, ran alignment tests, everything the help page says to do and it still doesnt work.
  • 446 Answers
If you said you have done and removed the tape and run all test, chances are the cartridge itself is the problem , return to vendor for a new replacement, this can sometimes happen
Posted on Jul 25, 2008
My printer is printing wavy lines and also has a faint line down the middle of the page.
It has to be because print heads are dirty. I find it is best to use the printer every few days whether you need it or not. Just print a test page to keep your ink from drying it the heads.
Mar 21, 2015 | Canon PIXMA MX472 WIRELESS OFFICE...
Prints pictures faded
On the pixma printer each time you remove a cartridge. you will need to do a clean of the nozles and print head. you can find instructions in your online operators manual. You hold down the wi-fi button and watch the
Home Click Here to Search
MG3500 series > Overview of the Machine > Maintenance > When Printing Becomes Faint or Colors Are Incorrect
Maintenance Procedure
Printing the Nozzle Check Pattern
Examining the Nozzle Check Pattern
Cleaning the Print Head
Cleaning the Print Head Deeply
Aligning the Print Head
Page top
error light flash. 1 flash release prints all saturation levels2 flashes prints the head alignment chart. 3 cleaning 4 flashes deep clean and so on. or its a transfer problem and this case do a transfer belt clean, and a head alignment.
Feb 28, 2014 | Canon Ink Cartridge for Pixma MP252
New black cartridge horz lines cleaned head &cartridge roller ; bought new cartridge still lines
Try to clean the print cartridge nozzles:
  1. On the printer control panel, press Menu.
  2. Press the down arrow button until you highlight Clean Cartridge. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  3. Print the document again to verify that print quality has improved.
  4. If print quality has not improved, try cleaning the print cartridge nozzles up to two more times.
You can also try to align the cartridges:
  1. On the printer operator panel, press Menu.
  2. Press the down arrow button until you highlight Align Cartridge. Press Select.
Jul 28, 2011 | Lexmark P4350 All-In-One InkJet Printer
Printer is only half printing doc on each line, have done test page, very faint, aligned ink, clean cartridges, all with top v faint and bottom dark ink, new cartridge last fri and was working well,...
Open the rear of the printer and make sure theres no paper jam or broken parts.
Try printing a document with the rear of the printer open and watch to see if anything out of the ordinary happens.
Mar 01, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
DELL 5110CN PRINTS PRINTS LIGHT GRAY NOT BLACK!
try to print test page and determinate which or colour is fainting. if it is one colour then you need to replace this colour image drum. If all of colors is fainting then its transfer roller.
Dec 29, 2009 | Dell 5110cn Laser Printer
Faint & White Lines in Printer Head Alignment
This sounds like you are using either a refilled cartridge or an after market cartridge and the ink is clogging the print nozzle. To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity, alignment utility. This should clear up the problem with the spotty printout.
Let me know if this solves your problem otherwise we can explore other solutiions.
Please rate this solution. Thanks.
Oct 06, 2009 | Canon BJ I6500 InkJet Printer
Poor printing
Gain new cartridges, possible that application time ended in yours.
Try to clean nozzles of cartridges by humid (wet) fabrics
Mar 01, 2009 | Lexmark X4270 All-In-One InkJet Printer
Very Faint Printouts
I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
Rgs
The StickMan
Dec 08, 2008 | Epson RX620 All-In-One InkJet Photo...
HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Nov 28, 2008 | HP LaserJet 1100 Printer
Faint blue horizontal lines
Try re-installing the printer driver it might be caused by a virus... if not then you need somebody to clean your printers head mechanism.. the blue cartridge might have messed an ink to its circuit.
Oct 27, 2007 | Epson Stylus Photo R200 InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
79 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
