Question about Ricoh Office Equipment & Supplies
How do I send scans directly to e-mail? - Ricoh Office Equipment & Supplies
  • 417 Answers
you may have to do it manually and send them via email attatchment, I could never get that function to work do to email security issues, my scans are in a "my scans" folder in my documents. Youll have to find that folder where your scans are by searching then manually . Open your email and get your email ready to go, choose attatchment and then browse for that scan in your computer, and send it that way.
Hope that helps
Posted on Jul 23, 2008
How do I send multiple scans in one email?
place all scans in a folder the send the folder to e-mail recipient
to do that right click on the folder you create and a drop box will open
in that box will be a --send to --and you will see mail recipient
click on that and an e-mail will open with the folder as an attachment
put in the e-mail address and subject heading
type any message you wnt in the body of the e-mail and send
Nov 12, 2015 | HP PHOTOSMART 7520 E-ALL-IN-ONE
Electrical wiring diagram
I've got one I can scan into a file and send to you via e-mail. I cannot send it here as the limit is 150Kb and the files are larger than that. To do it, you'll have to send me an e-mail and I'll send the file back to you as a JPEG attachment just like a picture. Contact me directly at Remind me of what you need.
Sep 01, 2010 | Harley Davidson XL 1200 C Sportster Custom...
I am trying to figure out how to use my Brother MFC-8440 scanner. I would like to use it to scan documents to email out. When I go to and look at the direction book, it doesn't have directions...
It is part of the Network User's Guide (section 10) and the Software User's Guide (section 3 for a PC using Windows, Section 8 for network scanning), not the User's Guide. The directions below are for XP and Win2K primarily. Slight changes may exist with other OS versions. (Full software is not available for Win7 so the buttons on the unit will not work. You will need to launch scans from the computer only. You can use Windows Paint or Fax and Scan without needing third party software. Then attach the file to an email either in the email software or by right clicking on the file and choosing Send to Mail Recipient.)
For either use, put the document face down on the glass or face up in the ADF.
If you use a directly connected computer, you need to set the destination for the Scan to E-mail in the Control Center (section 4-4 in the Software User's Guide). Open this program and make sure the correct machine is in the drop-down menu. This program needs to be running to hear the buttons being pressed. Click on E-mail to set which program will get the scanned document as an attachment for your e-mail. You can also set the resolution and type of attachment. If you do not want to use available file formats, you will need to scan in PaperPort (or other software) and then use that to attach the file to the e-mail. Then click Scan to launch the scan from the unit. Hit Set when ready to send.
If you have the unit set up on the network, then you can enter the LAN setup in the Front Panel (or a browser). Hit Menu 6 (and then the appropriate number for the next feature), such as TCP/IP, DHCP or Static IP (these are under 1), SMTP, POP3, Mail Address (Menu 6 2). Setup the Scan to email with Menu 6 7 1 for color and Menu 6 7 2 for black and white.
This automatically sends the item to the email server or PDF as either a PDF or JPEG. Then you need register the PC that will get the file to the unit, if you use scan to email (PC). (Your version of Windows will matter for exactly where the information is: Control Panel > Scanners and Cameras or Control Panel > Printers and Other Hardware > Scanners and Cameras.) Right click on the icon for the unit and select Properties to see the Network Properties box. Go through all of this set up including the Scan To Button. Then the Control Center will launch the e-mail program when it "hears" you press Scan, select Scan to Email, press Set, then choose PC and press Set again. (or select the destination PC which has e-mail access and press Set again). Scanning will start.
If you have set the POP3 and SMTP servers and the unit can directly access them, then you can scan to e-mail and enter the recipient address. Press Scan, select Scan to Email, press Set, choose Email Server and Press Set again. Adjust the scan quality as desired pressing Set at each step. Once you go through all of the layers, the LCD screen will prompt you for the recipient's email address. Then press Start.
I hope this helps.
Jul 20, 2010 | Brother MFC-8440 All-In-One Laser Printer
How does the 1210 scanner work with Windows 7? I have downloaded the driver for the printer and it works ok, but I cannot use the software for the printer. The copier and the scanner work, but i cannot...
You will have to do a two step process to send a scanned document or image by email; the scan to e-mail button won't work. Scan using either Windows Fax and Scan or Paint. Save your file. Then start (Compose/Write) an e-mail to the person you need to send the document. Click Attach and browse to the location where the scan was saved. The default folder is C:/Users/<user_name>/My Documents/Scanned Documents . Click OK after selecting that image. Finish writing your e-mail and send it.
If you'd like to automatically open the e-mail program, browse to the folder where you saved the fax from Computer (Start button) and right click on the image. Choose Send to Mail Recipient. The new mail compose window should open.
I hope this helps.
(a program like PaperPort may let you send to e-mail recipient without the extra step; however I'm not sure of the details.)
Mar 22, 2010 | HP PSC 1210 All-In-One InkJet Printer
Need to email documents in pdf format
Just scan or create the documents and save them as pdf files. Start your email & make them attachments.
Oct 29, 2009 | Dell 926 All-In-One InkJet Printer
How to scan to e-mail
Hi this is kamal....
pls read and do these steps carefully.. definitely u will get solution..
SCAN DIRECTLY TO E-MAIL FROM THE MACHINE- The direct "scan to e-mail" function was the hardest thing to setup. You have to have an actual POP e-mail address for your scanner, which is how it sends PDFs or JPGs of TIF files directly from the box. Getting an e-mail account setup is simple enough, but the control panel won't recognize the servers by name, for example standard pop mail server names list POP.GMAIL.COM. Instead you have to actually convert the server names into IP addresses (I found a website somewhere that did this) and insert that IP address into the control panel.
Once setup, the scan-to-email function works just as you'd expect. But it requires way too many key strokes on the machine to actually send the document. "Are you sure, Are you really sure, Are you really really sure?" (not exact quotes, but you get the idea)
I'm in my late-twenties with a background in the tech field, yet programming this direct-to-email function had me cussing and pulling my hair out. I imagine most people will setup the network scanning application and stop there. The network scanning application is actually a lot more versitile than the direct scan-to-email, even though it requires you to have your computer turned on. But using the network scanning the document just appears, then you can forward it to whatever e-mail you want via your computer (and keep your hair).
best regards
kamal singh
Oct 08, 2009 | Samsung CLX 3160fn All-In-One Printer
How to set scan for a new person on bizhub c351
After pressing "scan," press "Direct Input," then "Scan to E-mail." That will come up with a digital keyboard with which you can enter the e-mail. You'll have to type out the whole address, as on my printer (even though I have the manual) I can't seem to find out how to save it so you don't have to type it in every time...
However, after inputting the e-mail address, press "Start" and it should scan to the e-mail.
Nov 19, 2008 | Konica Minolta bizhub C351 All-In-One...
You can do this through the microsoft word. When you scan your document, your program will ask you where you want your document to go,you can direct it to ms word. you can send your email from microsoft word .easy
Note: it is important to install the software that came with the printer.It is this software you are going to work with to send your scan to ms-word,
Good luck
Jul 26, 2008 | Brother MFC 210C All-In-One InkJet Printer
Scanning for a Konica
Need to go to the user mode, press One touch,enter the address book, then Scan to email, there u can see all the address, select the one which u want to change it.
Jul 18, 2008 | Office Equipment & Supplies
209 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
