Canon imageRUNNER 400S Copier
Problem for Canon imageRUNNER 400S Copier
Gp300 formated hard disk
By supernetpro on Jul 23, 2008
thank you very much beaker020. I have also gp285 and gp300 with E0677. I accidentaly formated the hard drive and i don't have the installation CD to correct the problem.
CAN YOU HELP ME PLEASE.
Clarification Request
Posted by beaker020 on Jul 23, 2008
Maybe. Do you know if you have the H1/K1 printer option or the R1/P1 kit? It should be on a label on the printer board and on the hard drive.
BTW, if you pull out the PDL/IF pcb, (the board in the "cage" that the printer board connects to) then the copier will boot up without the error code and function as a copier only.
Solution #1
posted on Aug 31, 2008
Not Rated)
Maurader76
Rank: Guide
Rating: 85%, 9 votes
E677 is no system software on the hard drive of the Fiery Print controller. You may be able to find the system software at EFI.com (but I doubt it). The System must be installed with a utility called PDL Downloader.
Was this helpful?
Yes
No
Popular Solutions for Canon imageRUNNER 400S Copier
Questions and Unsolved Problems for Canon imageRUNNER 400S Copier
Do you recommend Canon imageRUNNER 400S Copier?
Answer
Answer
minolta 7145 - in ftp - error is -network connection not aviable n-87
Answer
what's the solution to fix the error code E014 for canon gp 405
Answer
need fax board for a canon image runner 400s
Answer
code pour anuller le probleme
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon imageRUNNER 400S Copier:
Top Copier Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
