Question about Samsung LNT3242H Television
Lose picture became dark
I got a Samsung LNT3242H a year ago. Recently, it suddenly lose picture became dark but still have sound, I hope someone can help! Thanks!
  • Anonymous Oct 23, 2008
    Screen goes black, still have audio, tapping the sides lightly used to work...LOL! What now??
I had the exact same thing happen on my LNT3242H, and we called samsung customer service as were still in warranty. The technician came out and made the diagnosis that the panel was out(which he said was a rare issue), so they had to special order a replacement panel and it took us a couple weeks to get the tv back.
So it could be a pretty big problem.
Posted on Oct 02, 2008
Look to solve this problemthree suggestions 1st check cables if they r properly connected 2nd check mak sure that its ont he right channel 3rd last if my fist two steps didnt work call tech support
Posted on Jul 23, 2008
Samsung LED TV problems
try first with the led strips noo need replacing t-con
Feb 27, 2017 | Samsung UN40ES6100 - 40" 6 Series...
How to fix an intermittent white screen on a Samsung television?
Ask them to replace the t-con board. It could be a defect one.Good Luck.
Serge.
Oct 01, 2015 | Samsung LNT3242H Television
After watching tv for several hours i suddenly lose the picture, but i still have sound
hi, not sure if you have the same fault as i had, but our tv only had half the screen go off, after looking up on the internet i found a video for a fix, what you need to do is remove the back cover, there will be ribbons that go from the front screen to the main panel, i removed each one at a time and rubbed the contacts of the ribbon with a rubber on the end of a pencil, plugged them all back in and switched it on and it was now spot on, thats more than a year ago and its still working spot on, hope this helps
jim
Mar 01, 2015 | Samsung LNT4665FX 48 in. LCD TV
When I snap it having lines and blur
Buy new camera and use it often. You don't use it you lose it.Oxidation on circuit connector, contact resistance became too high.
Jul 15, 2012 | Samsung Digimax S600 Digital Camera
The color on my Samsung LNT3242H TV suddenly is
Go to settings in menu and Reset to Factory settings...Hope this works
Oct 27, 2017 | Samsung LNT3242H Television
My Samsung LN-S2651D has sound but no picture
Check with Samsung, this model should still be under the 3 year warranty. You are having a problem with the backlight power supply. You can look on the back of the unit for the manuf. date, if its less than 3 years then go to www.samsung.com and process the online service request form.
I hope this helps,if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 20, 2010 | Samsung LN-S2651D 26 in. LCD Television
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Dec 17, 2007 | Samsung LNT3242H Television
Intermittently picture will lose horizontal size, now even the RT4201K fell of and no Degausing
make checks on the yoke, flyback,and the HOT they could be your source of problem.also check the horizontal circuit.good luck.
Jun 04, 2007 | RCA F32632SB 32" TV
Bad picture
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 26, 2006 | Hitachi 57SWX20B 57" Rear Projection...
Televison & Video Logo
253 people viewed this question
Henry  Thomas
Henry Thomas
