Question about HP Pavilion A610n (PC106A#ABA) PC Desktop
COMPUTER SHUTS DOWN
MY COMPUTER WORKS FINE UNTIL THE ENET CORD IS PLUG IN AND IT POWERS DOWN AND STARTS OVER TO THE WINDOWS PAGE AND IT KEEPS DOING THAT CANT CONNECT TO THE INTERNET ANY SUGGESTIONS
    New Friend:
    Problem Solver:
  • 12 Answers
I want to say just one thing that use Ethernetpedia App.then u understand many thing realated to it.
Posted on Dec 20, 2014
    Scholar:
  • 174 Answers
If your problem starts after enable your ethernet connection means it can be a network adapter (Ethernet card) problem or the cable problem.
When there is Hardware failure or malfunction in any device windows use to get restart - its a safety procedure that windows itself checking to correct the issue.
Check your network cable (ENET cord) for any damages or short circut with the help of a cable tester or connecting this same cable to a networked pc if its ok then you can check your network card driver and test the network card with ping command - to do so
Doing network card test
go to RUN -> type cmd then enter when u get the prompt type 127.0.0.1 if it reply three times then your card is ok otherwise try to replace it wil another pci network card.
Thanks
Hothawk
Posted on Jul 23, 2008
Go to Device Manager in that go to Network adapters and right click on ur Lan card go to properties, in that go to Power management and uncheck the box which say Allow the computer to turn off this device to save power
    Genius:
  • 1,019 Answers
Possible solutions:-
1:) Faulty Ethernet Card or Slot on motherboard. Possible sharing violation.
2:) Faulty-Broken-D Cable.
Solution:- remove card, and insert into another vacant PCI Slot.
check cable for kinks or breaks.
Mike @ Compurepair.
My computer was downloading windows updates overnight and froze. Tried turning it off from the power button, but did not work so I unplugged the computer. Few hours later I plugged the computer back in and...
You will have to get your power button unstuck. I do not know what type of button you have but if you would like to at least get your PC on without it instantly turning off, you can remove the power switch connector from the motherboard. You will eventually need to have the switch unstuck, or replaced though.
Oct 13, 2013 | Dell Dimension C521 PC Desktop
My lcd works fine untill i flip upside down
There is may be a problem with your power cable. You need to fix it properly.
Jul 23, 2013 | Dell ST2310 23 inch LCD Monitor
Keeps shutting down
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 12, 2013 | Computers & Internet
I have had my HP Pavilion dv6 1245dx laptop for a little over 2 years now and, up until about a week ago, have had no real problems with it. Recently, however, it has been shutting down by itself. So far...
hi
find out if the fan is blowing air -- tun notebook over and see if the air is blowing out from under it, while notebook is running. I would say that the heatsink fan may have stopped working, and it shuts down the computer as a fail safe response, so that the CPU or mainboard is not damaged.
other possibility, ---- the power connection (when inserting the AC adapter cord) may be faulty .to find out : remove the battery from computer (while computer is off). Turn computer on, insert the AC adapter cord. If notebook turns on, its fine -- if not and disconnects intermittently, you have a faulty AC adapter or power cord or combination/hop this helps
thanks for using FIXYA
Apr 13, 2011 | Computers & Internet
Laptop wont boot on, it starts but turns off again
I'm guessing ou have windows XP?
if so you hae a corrupted regisry and need to boot from your Windows CD and at he first et of questions choose Eneter to intall windows, then F8 to continue and then it should tell yo another Windows insatallation has been found and ask if you wish to perform an automatic repair.
Give it a try and enjoy :)
Jan 22, 2010 | HP Compaq Presario CQ50-210US Notebook
Can't re-install 2Wire USB Wireless adapter
If you are on windows vista it could be your driver. You can go into safe mode on the computer with F8 while the computer is starting up, then go to the control panel and device manager. Plug the adapter in and remove the driver for it. Download a new driver at http://support.2wire.com/index.php?page=download and install it.
Mar 30, 2009 | 2wire HomePortal 100W (1000-400026-000)...
Acerpower SV PC will Not turn off
More information would help to resolve this issue.
Are you shutting down by selecting Start and shutdown or have you tried pushing the power button on push (not holding the power button)?
Try this:
Press and hold the power button in solidly for about 10 seconds. If it shuts down before you get to 10 just let off the power button. This should work, but may not solve the problem.
If you reboot it and still can not shut down from Windows, hold power button until it shuts down, unplug the power cord and disconnect everything from the computer other than the keyboard, mouse and monitor. With the power plug still unplugged, hold the power button in for about 15 seconds (this resets the power supply and can clear a corrupt BIOS).
Reconnect power and after booting, see if you can shut down from Windows.
If still no go, click Start, Programs, Accessories, System tools and select System Restore.
Follow the prompts and select a bold date back to a time before you had problems shutting down. That should do the trick.
Let me know if you get it fixed or if you need more advice.
Honest1abe
Jan 02, 2009 | AcerPower SV PC Desktop
Booting problem in acer 4520
*********** board needs to be replaced
Dec 08, 2008 | Computers & Internet
Graphics card makes system reboot
Please shut down you're PC. Unplug the power cord from the PC. Remove the video card you have installed.
Once removed plug the power cord back in & start the PC. Press the delete key on the keyboard every 2 seconds untill the bios main menu loads. How to move around in the bios is shown at the bottom of each menu screen.
The Asus P4S800-MX motherboard has an onboard video card built into the motherboard. Before you can add a video card you must make a change in the bios. Go to Advanced menu.
Page 2-21 in you're manual. Change primary VGA bios to [AGP VGA Card].
Save & exit the bios. The PC will begin to restart. Press & hold the power button on you're PC until the PC shuts off. Unplug the power cord again, open the case & firmly & evenly insert you're AGP graphics card. Connect any extra power to the graphics card if required. Re-check all connections & cables before closing the case. Turn on the PC. Wait for windows to finish loading before installing you're video card software.
That's it. You're card should now function. Good idea to update windows!
Good Luck!
Mike
Jun 10, 2008 | ASUS P4S800-MX Motherboard
Monitor Suddenly Shuts Down
you should download and install the software for your computer model that controls the functions like increasing & decreasing screen brightness, switch between screens etc. Try reinstallimg the OS using the recovery CD ROM that came with your computer
May 17, 2008 | Dell Inspiron 1150 Notebook
HP Pavilion A610n (PC106A#ABA) PC Desktop Logo
82 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
