Question about IBM ThinkPad T21 Notebook
My ibm wont start up??????
Everytime i turn it on it goes to a black screen and says "error loading operating system" i dont have a start up disk...in fact i dont have any disks for it please help (ibm thinkpad t21)
    Genius:
  • 2,028 Answers
The problem is going to be with either the operating system or the hard drive, and you will need an operating system disc in order to solve this problem. After acquiring an operating system disc you can try an operating system repair. If the repair doesn't take, then try to reformat the drive (NTFS) and install a fresh version of the operating system. If you have any problems during or after the format and fresh install, then the hard drive has failed and needs replaced. A hard drive failure is the most common with this type of problem, but occasionally the operating system will glitch and cause it. Either way you will need an operating system disc if you plan on fixing this yourself.
Posted on Jul 23, 2008
I have a very weird problem with my computer screen. When i start my computer it loads fine but after seeing my desktoop the screen turns black after 10 seconds. If i unplug and power supply of my screen...
what is the os u are using, mention ur operating system, it is just a screen saver problem, try it in properties by clicking left mouse button on the desktop, is there any error message on the desktop when u got black screen
Aug 07, 2013 | Computers & Internet
"error loading operating system" message on dell inspiron 1420 laptop
only way to bypass this is use a recovery disk to boot from and then perhaps the issue will manifest itself
otherwise, it's the dreaded re format step
May 22, 2012 | Dell Computers & Internet
My A30 ibm laptop wont start up??
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 03, 2010 | IBM ThinkPad A30 2652 Notebook
No response at all
Hi dear, Its prasant, this is an operating system problem ,as u have formatted the system drive ,u do one thing try to format the whole hard disk, if it dont work let me know ,or mail me to prasant_rai2002@yahoo.com
Jul 09, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Computer wont load onto main screen
Simply fomat the hard disk, reinstore operationg system, and simply download drivers for installation from the ibm site.
Jan 09, 2009 | IBM ThinkCentre A50 PC Desktop
Computer wont go past a blue error screen
Your hard drive may have quit(died). No good solution other than replace the hard drive. Do you have a restore disk for you computer, to use after replacign the HD?
Here is the website for Acer PC
Dec 19, 2008 | Acer Computers & Internet
Technically Black Screen
when u power up the system press F8 key untill u get safe mode menu.
then goo to enable vga mode set your resolution to 800*600 or 1024 * 768.
also u can try safe mode or last known good config.
Oct 22, 2008 | IBM ThinkPad T20 2647 Notebook
Start up problem
This generally indicates a hard drive failure. You can try to do an operating system repair with the recovery or operating system disc, but most likely you will need to replace the hard drive.
When you see the IBM screen you need to enter the boot menu. On this screen it tells you what to press to get to the boot menu. Place the recovery or operating system disc in the drive, and select the CD drive from the boot menu, then follow the directions. If the repair doesn't work, then reformat the hard drive and install a new operating system. If you have any issues during or after the format or install, then the hard drive has failed and will need replaced. You want to do a full NTFS format, not the quick format, if the hard drive is bad, it won't format.
Aug 08, 2008 | IBM ThinkPad T30 2366 Notebook
Toshiba satellite with windows xp will only show black sreen and wont let windows xp repair
Your description of the symptom shows that your operating system installation has been corrupted. Fastest and easiest way to resolve the Issue using the "Recovery and application disk" (it comes with laptop) to perform full system recovery. I would like to remind you full system recovery will erase everything saved on Hard drive. You can check possible option on http://support.toshiba.com
If you dont have recovery and application disk you get one. You can call Toshiba @ 1-800-457-7777
Please post if you need further assitance
Good Luck
Jan 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
My ibm t40
If there is a problem in loading the operating system it may have been caused by some change. If you can work out what stopped it from working then you can try and reverse the change. Alternatively you can try to reinstall the operating system, to do this you insert the system disk that should have come with the computer or the OS if you upgraded it and follow the instructions. You may have to fiddle around with the startup options to get it to run the disk. Most computers access these through pressing F8 somewhere in the startup sequence.
Dec 01, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T21 Notebook Logo
170 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
