Question about GE WSM2700W Unitized Spacemaker Washer and Dryer
Washer will not drain
I have a GE Spacemaker Laundry system. I ran the wash and I can't get it to drain now. The washer will turn on but it keeps stopping and turning off. I now have all this water that I can not get to drain. Any advice?
  • kac5009 Dec 17, 2008
    I have the same problem. I checked the drain hoses. It does not sound like the pump is turning on at all. It stopps at the rinse part in all 3 types of cycles.
I just repaired one that had a needle stuck in the pump. Take the front cover off and the pump is in the lower left corner. Remove hoses and pull pump out then dis assemble pump and clean out.
If that does not do it you have to replace the pump.
Posted on Jul 07, 2009
Laundry machine won't drain, burning smell
check the pump under the washing machine might be a coin jammed in little fan in side the pump use a hose pipe to drain out the water
Jan 29, 2013 | GE Spacemaker Washer and Dryer Electric...
GE Spacemaker Washer Tan does not spin or drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | GE Spacemaker Washer and Dryer Electric...
WASHER NOT SPINNING
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 08, 2010 | GE Spacemaker Washer and Dryer Electric...
My GE spacemaker top loader will not drain, makes buzzing noise
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
May 29, 2010 | GE Spacemaker Washer and Dryer Electric...
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
GE WSM2480TBAW Spacemaker Laundry, Won't Drain or Spin
you need to remove the slanted panel between the washer and the dryer. There will be 2 screws holding the top of the washer to the cabinet. Locate the screws on the back edge of the washer top along with the 2 brackets that hold the top.
Once the brackets have been removed, the washer top panel will pull toward you and lift off of the cabinet. You will be able to see the lid switch and test it. If you are testing the lid switch for continuity, remamber to activate the switch while testing. If the switch shows an open circuit, replace the switch.
Please let me know if this hhelps you at all or if I can assist you further.
Thanks
Vic
Jul 23, 2009 | GE Spacemaker Washer and Dryer Electric...
Washer does not "click" to drain and spin cycle
Hi, Check the lid switch. Most models will not drain or spin when the lid switch is bad.
If I can get the model#, I wil try and asist you further.
Vic
Jun 21, 2009 | GE Spacemaker Washer and Dryer Electric...
GE WSM2700W Unitized Spacemaker Washer and Dryer Logo
411 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
