Question about HP Deskjet 2460 InkJet Printer
Troubleshooting HP Deskjet 2460
My printer a brand new one keeps power switch LED flashing. I verified the cartridges.
  • 5 more comments
  • rndc123 Jul 25, 2008
    I have a new D-2460 HP USB printer connected to a PC using Debian Lenny. The power on button light is flashing continuously.The jobs in the queue are held up.I hve installed the printer using CUPS and HPLIP.Please suggest .
    R.N.Daschaudhury
  • ken_na Sep 18, 2008
    i just installed a new black ink cartridge. the power button light flashes continuously and it wont turn off. it does not print also.
    pls help :(
  • adlibs Oct 06, 2008
    my hp deskjet d2460 printer's power light is blinking. it doesn't print. my jobs are pending/ pls help
  • petagaye9 Nov 17, 2008
    my power switch light keeps flashing and i am not getting an error message and it is not printing.
  • west5405 Dec 18, 2008
    I hv the same problem..
    power LED keep blinking..
    when test print not respon at all..
    cant close power button too..
  • pemerine Feb 24, 2009
    the printer power button blinks, it won't shut off unless you pull the power and it feeds a page through, prints nothing and then stops halfway and you get a paper jam error. to clear the print jobs I have to pull the power cord
  • Anonymous Feb 27, 2009
    the light is blinking and error and will not shut off and no printing as well as paper get stuck half way through
Hp deskjet d 2460, the printer icon is missing . pl note that we need to operate the machine
Posted on Aug 18, 2008
HP D2460 Deskjet printer power LED keep blinking when test print not respon at all cant close power button too..
Posted on Feb 21, 2011
Canon MP700 Multifunction printer displays message "Wrong cartridge"
1. With the printer powered off but connected to a power source, press the Power button while
pressing and holding the Stop/ Reset button.
2. When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4. When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in. (orange and green, starting with orange.)
Mar 24, 2012 | Canon MultiPASS MP700 All-In-One InkJet...
I've just put in all new inks and now ther is no comunication from my lap top to the printer. ive turned it off.. and the green light keeps flashing along with the orange intermittently,, Its driving to...
I suspect that the reason that there is no communication between your laptop and printer is because the printer will not switch online. This is further confirmed by one of the flashing lights. This is a standard feature if the built-in diagnostics of most current printers tells it that something is wrong.
Since as you posted/described "I've just put in all new inks and now..." was when the problem started, pls verify:
1. the ink cartridges are seated properly at their assigned slots;
2. most ink cartridges when new have a sticker cover of some sort to protect the electronic/contact pins. Pls verify that they were removed;
3. the cover/panel doors are securely lock in place;
4. verify that the USB cable/connectors are attached;
5. you have installed the correct model of ink cartridges, they are original and not generic/replacements/refills;
6. all others are where they should be, paper in tray, slides extended and nothing out of the ordinary;
If your concern has not been corrected after completion of the above procedures, pls post back with the brand and model of your printer. it might be of further help if you can post your laptop's brand & model as well as the operating system.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 13, 2008 | Computers & Internet
It won't print and the light keeps flashing. I lost the instructions!
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Feb 13, 2012 | Lexmark X1240 All-In-One InkJet Printer
Blue light keeps flashing on on switch
Dec 29, 2011 | Lexmark Z735 InkJet Printer
Toner light keeps flashing and printer won't print - even though it has a brand new cartridge.
Please try the following steps.
  1. Turn the printer OFF.
  2. Reseat the cartridge.
  3. Switch the printer ON.
Or
  1. Open the top cover.
  3. Close the top cover.
Jul 02, 2011 | Lexmark E232 Laser Printer
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
Error "Put in cartridge" Canon mp370 orange led keeps flashing
This is an issue caused when the cartridges entered are not the one which is usually used by the printer. Check the Cartridge make. It can also be caused of Dirty Cartridge contacts. If that is the problem then you have to clean the Cartridge contact and its connecting socket with alcohol. And most importantly, first check are the Cartridges fully inserted ans set in completely.
Thank you Sir, Have a nice day.
Sep 25, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Check cartridge
Lets try this first:
01. Verify that the unit is switched on.
02. Remove the power cable from the back of the machine.
03. Wait for 1 Minute.
04. Press and hold the POWER button on the front panel.
05. Reinsert the power cable in the backside of the unit.
06. Print a test page. If the problem persists, replace the cartridge.
What causes these symptoms?
These printers have a cartridge check feature. If it detects cartridge contact problems such as dirt, dust or oil on a contact, it will give warnings so the user can correct them by properly seating the cartridge and / or cleaning the contacts.
When a problem is detected, a software 'flag" is set within the printer that should be reset when the user corrects the contact problem.
Due to a firmware error, the 'flag' does not reset until the power is cycled to the printer and repeated warnings are delivered. Power cycling resets the 'flag' and eliminates the warnings.
HP has for years now stated the problem was corrected.
All the BEST
Jul 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My printer is not working properly. The light on the left (Amber Light, I guess this is what it is called) is blinking, but there is no paper stuck in the printer. How do I get it to stop and keep...
hello!
You will see 3 led lights on the printer. They will blink continously if:
if the print cartridge status light is flashing
-- check if the top cover is open, Close the top cover.
-- there may be a problem with a print cartridge
1. Verify that the correct print cartridges are installed.
2. Check if a print cartridge is low on ink or improperly installed.
if the resume light is flashing
-- the printer may be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of
-- the printer may be ready to print the second side of a two-sided document
1. Follow the onscreen instructions for printing the second side.
2. Press the Resume button.
if the power light is flashing
-- the printer is preparing to print
-- The light stops flashing when the printer has received all data.
if all lights are flashing
-- the printer may need to be restarted
1. Press the Power button to turn off the printer, then press the Power button
to restart the printer.Proceed to step 2 if the lights continue to flash.
2. Press the Power button to turn off the printer.
3. Disconnect the printer from the power source.
4. Reconnect the printer to the power source.Press the Power button to turn on the printer.
May 06, 2008 | HP DeskJet 940c InkJet Printer
Brand new Printer lights flashing
You should install driver first, then connect printer when prompted, then install inks, as it needs the driver to tell it there are full inks fitted, refer to the manual.
Dec 20, 2006 | Ricoh Aficio G7500 Printer
HP Deskjet 2460 InkJet Printer Logo
1,998 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
