SOURCE: No Flash function on Kodak Easyshare Z612
To both, I'm afraid you need to send the out camera for repair.
Camera flashes use a capacitor that holds the electric energy for the flash. It takes some time to charge and discharges very rapidly to generate the light pulse. Capacitors are notorious in their reliability. They tend to disconnect and die or short circuit and die.
In camera1234's case it might just died disconnected.
In sheranne case it might died short circuiting. In this case the camera should not be used since the battery might explode.
SOURCE: Kodak EASYSHARE M1063 won't turn on
For this problem try doing the following:
If problem persist call the 18002356325 for technical support for KODAK Digital cameras
Thanks
Hope this will help
SOURCE: My Kodak EASYSHARE M1063 camera won't turn on
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
SOURCE: When i go to charge my kodak M863 camera (in the
You can used the USB cable to charged the camera, But some of the M863 camera will not take charged usign the USB cable., I strongy suggest used the AC adaptor just make sure the AC adaptor is 5V ac adaptor it will only charged using the 5V adaptor., About the flashing green it indicates camera is charging just wait for the solid green light it means it fully charged
You may purchased also a special charger for your battery(KLIC-7001)- cahrer model is K8600-C. i think the price of this charger is around $29.00
SOURCE: Kodak easyshare M893 IS will not stay on. The
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
Contact KODAK:
