Posted on Jul 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CLC 4000 - Looks like Scratch marks in printed sheets
My canon clc 4000 started printing out what looks like "scratch" marks in the printed sheet. What could this be?
  • Anonymous Nov 11, 2008
    when I print in black and white the printed sheet comes out with scratch lines all throughout the sheet. Please help.
Chris Coughlin
Level 2:
  • Canon Expert 1,326 Answers
  • Posted on Jul 24, 2008
Chris Coughlin
Canon Expert
Level 2:
Answers
1326
Questions
Helped
441738
Points
872
Is it from the copy board glass or the printer part? Doses it show up in all 4 color making a neg copy in each color. If it shows up in the same spot on each color it could be the opc or transfer sheet. Also does it repeat it's self down the page.... Marks can come from one of three places.... opc,transfer,fixing... Need more info...... To broad of a Question
Canon CLC 1180 Copier Error Code: E071 0007
E071 / E072 / E073
Transfer Frame Connector
Poor Contact due to toner scattering around Transfer Connector
Replace Connector FG6 0948
TD Cleaner assy
Motor M8 being overloaded. Drive shaft from motor goes through long plastic bearings these were getting clogged with toner and oil
clean drive shafts
Transfer driver PCB
Static discharge onto transfer driver from peeling off old TD sheet too fast
Replace Transfer Driver PCB (FG6 - 2579) Remove old TD sheet SLOWLY to prevent problem.
I have a Canon CLC 4000, I have put new drums, and developers the fixing unit its OK. the glass(clean inside) too, but when i print o copy the colors are ok but a little Clear in some parts white spots...
If you haven't cleaned the optics and the coronas, do it. Always clean the machine, first. It'll save you money in the end. Not just the original glass. There are 3 optical mirrors in the optics cavity(underneath the original glass). One above the drum, and there are thre high voltage corona wires that get dirty.
White usually means that light is being blocked, and black usually means dirty coronas.
Don't know your technical level. if you need instructions
Let me know
Canon CLC 4000 won't Power Up
hi first of all cheq the required power for clc 4000 is tis 110V AC or 220V AC, secondly verify the outle of power from wall plug may yor machine 220v and you are putting on 110V
thanks
Canon CLC 1140 transfer issue on heavy or extra heavy stock
you must chose the bypass try to copy the heavy paper
Canon CLC 4000 Error code E013-0002
DESCRIPTION:
THE WASTE TONER LOCK DETECTION
SWITCH (SW4) HAS BEEN PRESSED FOR O.1 SECONDS OR MORE.
Solution: the waste toner is FULL.you have to get rid of that TONER.
2answers
I am looking for the Canon CLC 4000 service manual that I can download.
You might try www.justmanuals.com.It is a pay site but they seem to have everything.Good Luck
Can I print #10 envelopes on the 1180?
No, you can not print on a #10 envelope. The copier is not designed to. There are to many bend that have to be made to make a copiy and it has to wrape around the transfer sheet / drum. I take it you have tried and it jams ever time.....
Canon clc 5100 problem
try a clear server on the Fiery. shut down/re-start
**Warning if u need your job log saved do so before clearing Fiery server.
Black photocopiers
Dear sir; First thing you have to check is ,when you press print button does the exposure lamp is on, if not replace it. I would say that's the problem, if you need more help, just email me, I'm always around, good luck, DON'T FORGET GIVE ME A RATING
HAVE A HAPPY HOLIDAY !!!
old marine
old marine
ZJ Limited
ZJ Limited
