The following file is missing or corrupted; C:\WINDOWS\SYSTEM\VMM32.VXD type the name of the windows loader (e. g., C:\WINDOWS\SYSTEM\VMM32.VXD)
    Sergeant:
  • 313 Answers
That is a special file, created during Windows installation. Every computer uses a different VMM32.VXD file, so you can't simply copy one from another system and expect it to work.
If you can't find that file by searching the system in DOS, you could wipe the drive and reinstall Windows again, or do a repair install, installing Windows on top of itself. That should force the creation of a new VMM32.VXD file, and that problem should be history.
If you DO find the file somewhere on the HDD through a DOS search, copy it into the Windows\System folder, then reboot the system.
Posted on Jul 23, 2008
I deleted windows\system\vmm32.VXD on my etower633id
You must either recover that file from a backup, copletely reinstall windows, or use the Windows Recovery disk that came with your computer to repair the partition.
Mar 20, 2011 | E-Machines etower 633ids PC Desktop
Tip
NTOSKRNL.EXE is missing or corrupt.
Issue: NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution: Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
on Dec 27, 2009 | Computers & Internet
It doesnt want to start it says what im describeing.
From http://support.microsoft.com/kb/194679:
Cause:
This behavior can occur if the Windows\System folder is missing or renamed, or if the PATH line in the Autoexec.bat file is missing or does not include the Windows\System folder.
To resolve this behavior, use the appropriate method:
Method 1 loadTOCNode(2, 'resolution');
  1. At the command prompt, type: dir vmm32.vxd /s If the Vmm32.vxd file is not found, you must install Windows 95 or Windows 98 again. If the Vmm32.vxd file is found, note the folder in which it is located, and then continue with step 2.
  2. At the command prompt, type the following commands, pressing ENTER after each command cd windows
    ren folder system
    where folder is the folder you noted in step 1.
  3. Restart your computer.
Method 2 loadTOCNode(2, 'resolution'); Using a text editor (such as Notepad), edit the Autoexec.bat file and add or modify the PATH line so that it includes the Windows\System folder. For example, add the following line to your Autoexec.bat file: path=c:\windows\system
Hope this helps,
-LL
Mar 16, 2010 | Toshiba Satellite 2060CDS Notebook
Hi... my problem is my PC cannot find a VMM32.VXD
You can find instructions on how to get around this issue here. You will need to be able to boot to a command prompt from a Windows Startup disk. When using these instructions, be very careful about the commands you enter. You must make sure you don't mistype anything since it could cause more problems.
Jul 07, 2009 | Microsoft Windows 98 for PC
When I insert a cd in my player I get this error oe 0028:c182b573
Method ONE Disable the SCSI1HLP.VxD using the Microsoft Configuration Utility:
  1. Restart your computer, press and hold down the CTRL key while Windows is starting, and then choose Safe Mode from the Startup menu.
  2. Click Start, click Run, and then type msconfig in the Open box.
  3. On the Static VxDs tab, click to clear the Scsi1hlp.vxd check box, click OK, and then follow the instructions to restart your computer.
Method Two loadTOCNode(2, 'resolution'); NOTE: By following the steps below, any device that uses the Scsi1hlp.vxd file may not function properly or you may not be able to restart your computer. Some SCSI devices and some ATAPI devices use this file. If you are not sure if your hardware uses this file, check with your hardware manufacturer before you proceed.
Rename the Scsi1hlp.vxd file in the Windows\System\Iosubsys folder:
  1. Restart your computer, press and hold down the CTRL key, and then choose Safe Mode from the Startup menu.
  2. Click Start, point to Find, and then click Files or Folders.
  3. In the Named box, type scsi1hlp.vxd, and then click Find Now.
  4. In the list of found files, right-click the Scsi1hlp.vxd file that is located in the Windows\System\Iosubsys folder, and then click Rename.
  5. Type scsi1hlp.old, press ENTER, and then restart your computer.
Apr 04, 2009 | Microsoft Windows 98 for PC
Missing or corrupt files
well you will need a windows 98 disk to fix the problem. so if you don't have one or can't get one your best bet would be to take it to a technician.
Mar 08, 2009 | Computers & Internet
Computer won't boot up
You Can Try Using The Safe Boot Option Or Obtain A Windows Xp Repair Disk.
Jan 17, 2009 | Computers & Internet
Vmm32.vxd problem on windows millennuim edition its saying load windows loader dont knoe it please help have no disc omputer given to me thanks
just go to start button goto run type regedit and press ctrl F and then type vmm32.vxd and press find and if the file that type is showed delete the vmm32.vxd and press F3 to search again the if you find another file like that again just delete it and its finished restart your computer.
Nov 25, 2008 | Computers & Internet
How do I...
Related errors:
Cause:
Keyboard issue
Solution:
Keyboard issue
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
OS Loader v4.01
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
