Lennox CB26UH Air Handler stopped running - Heating & Cooling
  • 2 more comments
  • Anonymous Dec 13, 2008
    My honeywell thermostat cant seem to communicate with the cbx26uh air handler and blowers will not turn on... system sits there and does nothing.
  • Louis Vadala Apr 06, 2009
    I have a Lennox 10 year old Air Conditioner in my Condo and the Blower is not turning on.  But if I open the unit up and give the blower a spin, it runs fine, just wouldn't startup on its own.  any ideas or help would be greatly appreciated.
    Thank you
  • Anonymous May 23, 2009
    air handler makes a knocking noise
  • Anonymous Mar 16, 2014
    no heat lennox ghr26Q3/4 air handler working no flame in fire box
  • 143 Answers
Do you mean the air handler fan doesn't run but the outside part runs? If that is the problem, try turning the fan blade with a stick. If it turns freely, you have an electrical problem. It could be a relay, a bad motor winding, a bad capacitor, or a bad thermostat, among other things. If the fan won't turn, the motor needs to be replaced.
Posted on Jul 25, 2008
Why does our Lennox AC Air Handler, Model CBX26UH-060 makes a beeping sound when it starts up?
Dear Friend,
Normally all Lennox handler beeps right after turning on and off, but if beeps all the time it might be that there is an error with the handler or it beeps because it was program to beep when going on and off. Please refer to your user manual for any beeping error.
Good Luck!
Sep 20, 2014 | Heating & Cooling
Lennox ac stops working after normal shutoff untill i shut off power to air handler turn power back on ac runs till nornal temp reached shuts off will not come back on untill i kill power to air handler...
The 13HPX is a Heat Pump. It has a control board in the outside unit that will lock out after a few trips from one of the controls, such as a low or high pressure switch tripping. Turning the power off is making this board reset. Take the door off next time. to the outside unit and look at the lights on the control board. There should a sticker on the inside the door that you have to remove that describes why the unit is hard locking out according to the light configuration.
Oct 24, 2017 | Heating & Cooling
Lennox Elite air handler will run cold for a while, then it will blow warm air out until the safety switch is moved, then it will make a noise in the system which sounds like air hissing, then the cold air...
sounds like installer broke on yellow wire between thermostat and condenser. your switch is breaking the 24 volt signal to cobdensor when the internal float is activated. moving the switch is somehow allowing bobber to drop enough to reactivate 24 volt and condenser comes back on. refrigerant starts to recirculate again and thats what your hearing in the lines. the switch prevents evap coil pan from spilling over into your return when the drain is clogged. use a shop vac and clear your drain. i blow it out with compressed nitrigen. after line is clear prime it wuth 32 oz of water.
Aug 07, 2013 | Heating & Cooling
My air handler sprung a leak and needs to be replaced. Would it be a bad idea to use a Lennox CBX32MV-048 variable speed air handler or is it better to get a carrier air handler?
They are expensive to buy, and to replace it as well. I would not to expensive. Any air handler, just not a variable speed.
Jul 06, 2011 | Heating & Cooling
I have a Lennox A/C and air handler with a honeywell thermostat and the purge light is blinking. What can I do? I am not getting cold air.
check with thermostat commands from indoor to outdoor.May be your outdoor unit doesn't have command to operate.
Jul 24, 2010 | Amana PTH123B35AE Air Conditioner
I have a Lennox CB29M Air Handler with an electric heater, which is used to heat the lower two rooms of my house. The handler unit is located in a mud room right behind the back patio. I'd like to get an...
Any of these Lennox dealers can help you choose a compatible HS29 or HP 29 condenser and evaporator coil to match your system.
http://www.lennox.com/locate/default.asp
Jul 06, 2010 | Heating & Cooling
Drip pan wet furnace filter lennox air handler
verymuch so it is clogged up , now open system treat drain pan with bleach ,blow out two lines if there are available but if theres only one treat that on ,then treat the coils clean an treat them after cleaning pour little bleach in the bottom of the pan
May 23, 2010 | Ruud UBHC Air Conditioner
Air handler too large for heat pump doesnt heat or cool properly any options to get unit to prefrom better like pistons or txv
I would check with the manufacturer and check on the right sized air handler. The txv or piston has been engineered to function with the system you have and this will change the dynamics of your system by altering the metering device.
Jan 06, 2010 | Heating & Cooling
3 year old Lennox system stops intermittently 2-3times past 24hrs
i would have the thermostat receiving 24 volts all the time by running the c terminal from the air handler to the thermostat and go from there
Jun 21, 2009 | Honeywell Heating & Cooling
Heating & Cooling Logo
1,334 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
