Question about Microwave Ovens
I have a Kenwood Microwave model KEN GT/AL17 Ser No 0631003623 the door catch/locking unit which is in the door is broken can you give me a part number and where to get one Many Thanks Dave Shemwell
3 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: I HAVE A KENWOOD MICROWAVE GT/AL17,THE TURNTABLE
Two possibilities: either the turntable coupling is broken or the turntable motor has quit. The plastic coupling can wear or crack so it no longer fits properly on the turntable motor shaft. Then even though the motor still turns, the turntable doesn't. Or the motor itself may have stopped working. If the plastic coupling still looks normal and you can't rotate it easily by hand while it's in place, it's probably the motor.
I'm here in the US so I can't suggest where to find parts, but you should be able to locate a supplier who might have replacements available. Of course the oven will still work without the turntable running. You'll have to open the oven occasionally and turn the food yourself to insure even cooking.
Posted on Jun 03, 2009
SOURCE: my kenwood microwave KEN GT/AL17 wont cook
This is most likely the high voltage fuse between the transformer and the magnetron. An easy and cheap fix.
Posted on May 04, 2010
I pushed in the white piece where the door catches and the microwave will not run and the light will not go on
You've broken the door catch. You'll have to take off the outer casing and check whether they assembly has simply come loose or whether it's broken and in need of replacement.
As you haven't given specifics regarding make and model I cannot be any ore specific myself, but it's a very straightforward job and is usually almost identical regardless of make and model.
May 20, 2010 | Microwave Ovens
My kenwood microwave KEN GT/AL17 wont cook anything. The light comes on and it turns but theres no heat?
Oct 22, 2009 | Microwave Ovens
I HAVE A KENWOOD MICROWAVE GT/AL17,THE TURNTABLE HAS STOPED TURNING, ANY ADVICE MANY THANKS. TONY Nr IRRLAND
Jun 03, 2009 | Whirlpool MH7140XF Microwave Oven
Kenwood KEN-GJ/SS25 Microwave Oven
There is a fuse inside on the right side. Covers are easy to remove but there will be torx safety screws usually only 2
Feb 16, 2018 | Microwave Ovens
Front door closes on a model R-1610-11-12 but light does not go out and microwave cannot be started up. Door does not seem to latch in place. In lower door latch inside the microwave I can see a plastic...
hi check that the door catch is locking into place maybethe locking mec is not engaging or triping the micro switch ,if it does n't trip the switch it won't turn light off and unit won't work
cheers grant
Oct 22, 2008 | Sharp Microwave Ovens
My KEN GT/AL17 is displaying a "g" icon under the time display and will not function. Any ideas?
As requested, the Microwave was unplugged overnight but the hard reset did not work. The lower-case 'g' is still showing
Sep 25, 2008 | Microwave Ovens
NEED TO REPLACE THE WHITE PLASTIC CATCH ON NEXT TO THE CONTROL PANEL AS IT SNAPPED OFF AS MY SON SLAMMED THE DOOR
By the nature of the oven main face plate and the locking latch being attached to the safety system the replacement cost is usually higher than a replacement microwave oven.
In your case replacing the microwave with another one is more sensible. Your oven is an obscure model as it is, I'd suggest a sharp brand.
Regards,
Worldvet
May 15, 2008 | Zanussi ZM24STX 900 Watts Microwave Oven
Kenwood microwave (KEN GJ/SS25) heating doesn't work but grill works
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 24, 2007 | Sharp R-303CW Convection / Microwave Oven
Microwave Ovens Logo
157 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
