WANT TO HAVE MY TELEVISION REPAIRED
THE ON OFF SWITCH IS BROKEN I TURN IT ON IT SHUTS OFF
  • Anonymous Dec 14, 2008
    How expensive is it to repair and is it worth it?
What brand and what year and model #
Posted on Jul 23, 2008
06 ultra glide radio occasionally shuts off volume,I turn off radiothen turn back on , it resumes sound. Latelyradio has poor sound qualitythat has gotton progressivly worse. Any ideas how to repair?
You have a damaged audio circuit caused by vibration. Check the bikes fairing brackets. probably broken. The radio will need to be repaired. www.ironcrossaudio.com
May 17, 2014 | Harley Davidson 426290 AM/FM Radio
47pfl5704d/f7 shuts off
possibly a dry soldered joint, when the television gets warm the contact is broken as the soldered joint has become loose. it is an easy cure if you can discover the fault, basically resoldering the joint. but can be difficault to find. i have normally done this using a freeze spray(must be designed for electrical applications). spray the circuit board insmall areas. when the relevent part is rapidly cooled the contact will again be mmade and the television will work until the joint heats up again once it goes again spray again to check. switch off and re-solder
Feb 02, 2013 | Philips Bundle 47pfl5704d/F7 Tv Nxg...
Turn signal and high beam switch is broken. Can it be taken apart and repaired?
I do not have a solution but have the problem switch high low is broken.
how do you replace it?
Jan 30, 2012 | 2002 Mitsubishi Eclipse
When turning on, it makes a weezing noise three times and after the third time shuts off. not even enough to warm the tubes
Hello
Something wrong with its horizontal output stage. Never switch ON the TV till the fault has been rectified. It may cause more components to burn out. As the fault occurs for just a short period of time, it will be very difficult even for an experienced service technician too to point out the exact thing happening. Get it repaired by someone whom you know well experienced in servicing RCA TVs, or send it to RCA authorised service center and get it repaired. OK.
Apr 16, 2011 | RCA D52W19 52" Rear Projection Television
Shuts off after 5-10 minutes
Your tv power supply is over heating and that is why it shuts down. Think of a hair dryer that shuts off after over heating. It is a safety feature. Depending on the age, it is most likely a 100 lb paper weight. Find a place that takes broken tv's and get a new lcd.
Aug 09, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
My antenna switch wont turn on, can i turn it on a different way?
if the switch is stuck or broken in the off position there is no other way to turn it on you will have to have it repaired
Jul 27, 2009 | Computers & Internet
TV shutting off
its the problem of ic numbers 438 or ic nuber 453 getting overheated on the main board .this ic needs to be checked and repaired.
Mar 06, 2009 | Sanyo DP32746 32 in. LCD Television
Tv won't turn on...
the internal power supply needs to be repaired.
call us we do ups repairs.
thanks
hope this is of help to you.
719 687 6997
Nov 26, 2008 | Emerson EWL20D6 Television
My tv turns onn for a few seconds then shuts off
it can be repaired but it would be easier to buy a new tv and cheaper
Oct 22, 2008 | Samsung HCM422W 42" Rear Projection...
Pioneer SD-P55A5 Shuts off and must be reset with Main Power Switch
if you are not a tech take your set to be repaired your tv illness is in the power supply or related circuit.good luck.
May 14, 2007 | Pioneer SD-P55A5K 55" Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
