Question about Xerox Office Equipment & Supplies
How do I turn off red light after installing new drum in Workcentre 555?
  • jayb_remcorp Jul 23, 2008
    after restart, red light is still on.
    solution satisfactory
    Genius:
  • 3,422 Answers
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode
Posted on Jul 23, 2008
  • Priya darshan Jul 23, 2008
    Please don't forget to accept the solution as fixya.
    Sergeant:
    Champion:
  • 310 Answers
When u restart the printer automatically it will turn off.............
Changed drum on workcentre 4118, and still says change drum
TURN ON MACHINE. PRESS MACHINE STATUS; PRESS ADMINISTRATIONS TOLS;PRESS ARROW HIGHT UNTIL APPEAR M ANUTENCE; PRESS OK; PRESS ARROW HIGHT UNTIL APPEAR "NEW DRUM". PRESS YES.
PRESS OK. THATS IT.
TURN OFF THE MACHINE; WAIT FOR 30 SECONDS; TURN ON.
Feb 12, 2013 | Xerox WorkCentre 4118 Network Kit...
My fax says replace drum, which we did, but it won't reset/restart. What is wrong? Is there a code we need to enter?
Yes there is a code, it has been so long I worked on these machines, need to find it.
I will come back later if I do find it and post it.
Jan 25, 2011 | Xerox WorkCentre Pro 555 Plain Paper Laser...
DRUM LIFE WARNING WON'T GO AWAY AFTER REPLACING DRUM.
find the box that the drum came in. There should be directions to reset the drum light enclosed. Or go to www.xerox.com , then look under support and drivers. Good luck !
Jan 11, 2011 | Xerox WorkCentre Pro 555 Plain Paper Laser...
I have a workcentre pro 215, this have a circle red light on, somebody could help me? thanks
That is the signal to reaplace the drum cartridge. It has a life of 18-20 thousand pages and then that light comes on meaning it needs replaced.
Mar 08, 2010 | Xerox WorkCentre PRO-215 All-In-One Laser...
Right side of Print Out is faded. Cleaned, and Cleaned. Doesn't say to change drum/ink. What else can we try?
You can try shaking the toner cartridge to even out the toner but most likely either need a new toner cartridge or the drum is not sitting evenly as it should.
Sep 11, 2009 | Xerox WorkCentre Pro 555 Plain Paper Laser...
I have a Xerox XD125F Workcentre. The J2 toner
1. turn off XD125f
2. Turn on
3. within 4 seconds press, clear, auto, clear, auto. LED Should go blank,
if not try again
4. use copy quantity keys to enter 24, then push start
5. Again use copy quantity keys to enter 7, then push start
6. turn off
when you restart the cartridge count will be set to zero
I have done this twice and never replaced the drum cartridge.
Jul 24, 2009 | Xerox Office Equipment & Supplies
J2 Error on XD125F
With that machine, what frequently happens is the flag in the drum unit falls down during shipping and does not swipe the drum replacement switch.
You can do one of 2 things, Exchange the drum cartridge or, on the front of the cartridge you have to remove the green cover, Remove the clip and pop off the gear cluster. Then look at the one gear in particular that has a flag like protrusion. Rotate it so that it stops up and to the right, so that when you place the drum back into the machine it can rotate down and hit the switch that tells the machine you replaced the drum.
That flag only runs a half turn, one time at install. And if it has fallen in shipping hte J2 will not clear.
That is what has happened. It is pretty common.
Sep 17, 2008 | Xerox WorkCentre XD130DF Laser Printer
Replace Drum
your toner has nothing to do with sending/receiving faxes. If you can print to the xerox...something is wrong with the software..
delete and re-install software..Xerox website is useless
check the black sensor that dangles into the paper tray. wiggle it up and down, ahten resintalled the tray
Aug 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
WorkCentre 555 Fax Drum
This will reset it for you. strange !!!!!
    1. Yes
    2. No
Mar 14, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
82 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
