My laptop wont shut down its been tring to shut down all day i have tried to swich it off but when you switch it back on it still trys to shut down
    Sergeant:
  • 313 Answers
Remove the battery, and unplug it.
Posted on Jul 23, 2008
How can i switch on back my lenova k1 android tablet that wont turn on?
Hello Ruth
If you tried the reset and it didnt work then most likely it wont come back to working again. Does it give any sign that it trys to power on?
Chadman
Nov 22, 2014 | Lenovo IdeaPad K1 10.1 inch Tablet NVIDIA...
How do i test the power button on a toshiba equium l40 laptop
OpenControl Panel, Power settings, Advanced Power settings, change SLEEP to Never, Hibernate to never. Shut down and unplug, if you use mostly on AC, remove battery, your laptop when not in use. It will last longer, if there is a power surge not be damaged, and a reboot every day resets the computer.
Dec 26, 2012 | Computers & Internet
Compaq presario b1900 fails to give output to monitor. If output comes out it gives blue screen and shuts down. If you switch on again the fan and disk do run but no output to screen. An external monitor...
That blue screen and shut down, means a problem on both OS and Hardisk.
If you got any hardisk for that laptop. try it and am sure it will work.
The faint beep means a good memory card.
Hope that helps!
Dec 02, 2011 | Compaq Computers & Internet
Tring to run restore disk but laptop kepts shut down
Maybe it's shutting down because it overheating. Check all your air vents for dust buildup. Use an old toothbrush to brush the dust away from the vent holes and blow air through the vents using one of those compressed air cans made for cleaning keyboards. One time I worked on a Sony laptop that I had to take apart to get all the dust cleaned out of the air vent. You can also try running your restore disk with the laptop sitting right next to a window A/C unit. Try to position the laptop so it gets maximum exposure to the cold air of the A/C unit.
If you get the laptop working again and you think overheating is a problem I recommend downloading a free piece of software named FanSpeed. Here's a link.
http://www.softpedia.com/get/System/System-Info/SpeedFan.shtml I'll let you read the description for yourself, but in short it allows you to monitor the temperature inside your computer and to adjust how the fans react to this temperature.
Jun 02, 2009 | Acer Aspire 5100 Notebook
HAVE HP PAVILION DV 9000 LAPTOP , WHEN I SWICHED ON MY LAPTOP IS ON BUT SCREEN IS NOT WORKING AND EVERY ONE MINUTER LAPTOP GETS AUTOMATICALY RESET. SO PLEASE GIVE ME REPLY WHAT IS THE PROBLEM?
I have had this same problem with a HP DV2000 and the problem is not the contrast light. What it is, is that the laptop thinks that the screen is been shut down that is why the light does not come on. The best way to solve this is to remove your keyboard first.
You can remove the keyboard by removing exactly 7 screws from your laptop back, there are 5 screws located under your battery and other two that are in the location of your RAM'S.
Just open them up and then you will notice that the key board pops out abit then just simply take it up and then just below the keyboard, on the same line where HP brand logo is on your machine there are two small clip types of pind, that you can remove and put back.
There is a clip that is hidden abit under the metal plate, so just try and remove that clip from its place using a needle or any long and thin object.
That will make the laptop not have the problem. But once you remove that the laptop constantly will think that the screen is open even if you close it. then after like a week or two you can put it back and all shall be fine if not then just remove it and keep it out.
You can then set your power options to shut down the screen light every 2 minutes or something like that so as to avoid the backlight being switched on all the time.
Hope this solves your problem.
May 28, 2009 | HP Pavilion dv9000z Notebook
Dell 610initial start up problem
Hi!
You are unable to enter bios....to select drive c...try to remove the hard drive and install it in the other machine that you have....or just boot your notebook without the Hard disk and see if it makes any difference.....
Can you explain more on...
"The computer trys to start and then just shuts down in approx, 8 seconds."
Nov 13, 2008 | Dell Latitude C610 Notebook
Door locked, start pause light flashing
I also have the same problem. I have got it to work by unplugging for a day and night. When I plug it in the next day it works like new for a couple days and then back to the same old "door locked" problem when the door isn't locked........BIG HEADACHE!!!!
Jun 11, 2008 | GE WSXH208A Front Load Washer
Aspire 5100
Hi Fayez,
How soon does the laptop switch off? Immediately, or a few minutes into booting into Windows, or ... ?
It could be an overheating issue. If you're using it on your lap or on a soft surface such as a couch or bed, the fan might not be able to release the heat.
Try putting something underneath the back of the laptop and place it on a stable surface such as a desk and boot it up - see if it still shuts down.
Otherwise, let me know how soon it's switching off, or at what point if it's the same point every time.
Ben
Mar 07, 2008 | Acer Aspire 5100-5033 Notebook
Computers & Internet Logo
David Payne
David Payne
