Question about Canon PowerShot A720 IS Digital Camera
Just bought it... 'My colours' option is not accessible.
I followed my manual but when I scroll down the left hand side icon column... it skips that option (which is set to off) my metering mode, and my flash exposure as well.
What should I do?
Thanks in advance.
  • loa247 Jul 23, 2008
    Thank you so much! I was starting to think I got hold of a dud!
  • 2,131 Answers
Those options are only available when the camera is in P, Tv, Av, or Manual modes. When in the Auto mode or one of the scene modes, the camera sets these options. (See pages 206 - 209 in the manual.)
Posted on Jul 23, 2008
I forgot password and now I cant access my tablet.
Here are some options which came from the trio tablet website: What do do if forgot my password to unlock to my tablet
Factory Data Reset - Factory Data Reset can be accessed through your Settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From Settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD Card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset Tablet and Erase Everything.
  1. Tap on Settings.
  2. Tap on Backup and Reset on the left hand column.
  3. Tap on Factory Data Reset on right hand side.
  4. Tap on Erase SD Card. (optional)
  5. Tap on Reset Tablet and Erase Everything.
Or
Hard Reset G2 - In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults. First you need to make sure your tablet is powered off. Hold down on the Volume + button and hold down the Power button at the same time. As soon as the tablet's screen turns on let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen. At this point you will see a screen with boot options. Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option. On the next screen use the Volume - button again to go down to Yes and use the Power button to select. At this point it will be going through the wiping and resetting process. When it's done you will see the first screen you came to when you first started the setup. Just tap the Power button to select Reboot System Now.
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset
  6. Tap Power button to select.
  7. Use Volume - button to scroll to Yes.
  8. Tap Power button to select.
  9. Tap Power button to select Reboot System Now.
This site also had some tips: Different Hard reset factory wipe methods for Android Tablet
Mar 21, 2016 | Audio Players & Recorders
I forgot my password for my trio stealth g5 7 can u help me reset it or something?
I Forgot My Password To Unlock To My Tablet? Factory Data Reset - Factory Data Reset can be accessed through your Settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From Settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD Card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset Tablet and Erase Everything.
  1. Tap on Settings.
Or
Jan 04, 2016 | Tablets & eReaders
The scroll bar in my laptops' touch pad isn't working.
The scroll on your laptop is controlled by the trackpad installed on the system.
If you are having problems with the scroll on your laptop's trackpad, there is something you can do before you take it into a computer repair shop.
Updating the driver to the trackpad will enable the scroll if it is not working at all.
Once the driver is updated, your scroll should work again.
You can access the driver through the Device Manager on your laptop.
Click the "Start" button, then click the "Search" option.
Type "Device Manager" into the search bar and press the "Enter" button.
Click on the "Device Manager" icon from the menu, then scroll down to the "Track Pad" icon on the left side of the screen.
Click on the icon, then click the "Driver" tab at the top of the window. Click the "Update" driver option from the window.
Wait for the new driver to install on your computer.
This should take about two minutes to complete.
A window will appear telling you that the driver has been installed.
Put your fingers on the touchpad to move the mouse around on the screen.
Hope this helps.
Nov 27, 2012 | Dell Vostro 1015 Laptop
Can not get password to use on iPad or iPhone to work using password
If you are asking about the passcode that locks your iPad or iPhone so others can not access it, following the steps below.
-Start with the iPad screen off.
-Press the HOME button (the small circular button close to the screen)
-Slide to unlock the screen, at the bottom.
-Press the HOME button until you see a box that says SEARCH IPAD (the keyboard will also slide up when you're on the correct screen)
-In the box that says SEARCH IPAD, type SETTINGS
-At the top of the list, created by typing SETTINGS, should be the TOP HIT of SETTINGS.
-Select SETTINGS by tapping with your finger.This will open the SETTINGS app.
-On the left hand side of the two columns, in the SETTINGS app, should be a list of options. Select the GENERAL option from the list by tapping it with your finger.
-On the right hand side of the columns should now be a list of more options starting with ABOUT.
-Continuing looking down past the ABOUT option for the option PASSCODE LOCK.
-Select the PASSCODE LOCK option by tapping it with your finger.
-A new menu, on the right hand side, should now appear starting with the TURN PASSCODE ON option.
-Select the TURN PASSCODE ON option by tapping it with your finger.
-The SET PASSCODE pad should appear in the center of your screen. Enter a four digit passcode of your choice.
-Reenter the passcode you chose again.
-You are done! The next time your iPad times out or you lock the screen, it will require the four digit passcode you set by following the above steps.
Oct 19, 2012 | Cell Phones
Desktop, accer computer, can't unmute microphone? How do you unmute the microphone?
Hi queen17186...
Go to the bottom right hand side of your computer screen, look for the speaker icon, double click the speaker icon, a window will open and show you the volume control, make sure none of those are checked "mute".
Then go to the top of that window left hand side and click on "options"then click "properties" scroll down and make sure "microphone" is not checked.
This should clear your microphone problem.
Please take time to rate me
Aug 31, 2011 | Computers & Internet
Hello i have toshiba laptop model 1415 S115 my screen colour is very dark and i cannot adjust my screen colours please tell me and is any shortkey to adjust colour of laptop thanks.
Hello
Click the "Start" tab in the lower left hand corner of your Toshiba laptop's screen. From there, go to Settings and wait for the column to pop up. Scroll up the column and click on the "Control Panel." While the Control Panel window is open, click on the "Display" icon.
Press the tab labeled "Settings" while in the Display Properties window. Locate and click the "Advanced" button.
Click the "TwinView" tab from the window that automatically pops up at the end of Step 2. While in the "TwinView" tab, ensure that "Display" is set at "TwinView Display 1: Digital Flat Panel."
Locate and press the "Output Device" button. Click on "Color Correction" and adjust the brightness of your Toshiba laptop.
Apr 15, 2011 | Computers & Internet
I installed Cydia iHome on my phone. I don't have iHome as an icon and now I can't access my Settings icon. need help pls.
iHome has hidden your settings icon, by design.
install SBSettings from Cydia.
pull down the SBSettings menu and tap 'More' in the lower left hand corner
scroll to 'Hide Icons' under System Options and find the Settings application, switch it to 'ON'
Dec 06, 2010 | Apple iPhone 3G Black Smartphone
Vertical scrolling not working
you can activate this by
1. going to the control panel on your vista machine, make sure you are in classic view
(2) double click the mouse icon.
(3) From here you will select the "Device Settings" tab,
(4) make sure your Synaptic Pointing device is highlighted and then click the settings button located directly below the "port" column, this will bring up properties for this device.
(5) With all categories in the left hand column collapsed, select "Virtual Scrolling" here is where you will find the box that needs to be checked to enable vertical and/or horizontal scrolling.
(6) make sure the "Enable Vertical Scrolling" box is checked.
(7) don't forget to hit apply!
May 22, 2009 | Compaq Presario CQ60-220US PC Laptop
Date stamp
In order to use the date stamp option, the image size (L, M1, M2, M3, S, Postcard) has to be set to Postcard. Press the Func/Set button, scroll down to the image size icon (lower left corner), then scroll over to Postcard, and press the Func/Set button again.
Jun 10, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
I have a canon powershot a560. i would like the date on the pictures. i followed the manual which says turn on date stamp in the menu but it skips over the date stamp so i can't change it. any suggestions?
When you turn your camera on, there is a screen which appears in the viewfinder. Push the FUNC SET button and then scroll down the column on the left of your viewfinder until you come to the one with the letters M1 M2 M3 S, etc to the right. Then select the one called "Postcard 1600x1200" by scrolling to the right. Your camera is then in the post card mode. You can then go to the date stamp in the menu and your camera will not skip over it any longer! EUREKA!!
Apr 11, 2008 | Cameras
Canon PowerShot A720 IS Digital Camera Logo
53 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
