Question about Motorola Mobility H700 Wireless Headset
H700 - microphone not working or am I on mute?
My h700 is fully charged - and when I make a call the voice microphone does not work but I can hear the call fine. Is there a chance I muted it and if so how do I unmute it?
  • 4 more comments
  • fatarse Jul 23, 2008
    my h700 was fine and it is as above very low when i talk as if i have turned it down low
  • steyer Jul 26, 2008
    My motorola H700C bluetooh headset has worked fine for 6 months but now the microphone doesn't seem to work or is very very low. I can hear conversation fine but noone can hear me. Is there a way to adjust the microphone volume or reset the device?
  • jim_georgiou Sep 19, 2008
    I read this today and tried the 'remove the microphone pad' tonight and my headset seems fine now. One thing different than the instructions, I removed the sticky goo from the microphone pad and put the pad back in place. The rubber cover holds it in place. The goo is probably melted glue or pad from heat and I can see how it happened over time, either wearing the headset or having it in my car during the summer.
    Thanks!
  • von13 Oct 14, 2008
    my microphone isn't workin but i can hear the conversation on the other end but they can't hear me.Motorola h710
  • uretsky May 11, 2010
    Dude! You totally rock! Thanks a ton!
  • djterry11 May 11, 2010
    Steyer, if I could find you I would kiss you!!!! Thank you! You saved me a ton of money! The little black foam thing inside mines was melted on the mic like rubber. No wonder no one could hear me.
    ~Jen
Ok here is the answer. There H700 have a small foam windscreen inside over the microphone that over time block the sound. The answer is to carefully open the unit and remove the obstruction and clean residue from the microphone and it will work like new. here is a link to pictures and instructions. http://www.geocities.com/jconkwright/H700fix.html
Posted on Jul 26, 2008
Thanks steyer. It is working now!!! I almost put my headset in the garbage.
Posted on Sep 26, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
Thanks this worked great. It only took a few minutes.
Posted on Oct 12, 2008
Why is Voice not able to be heard on incoming/outgoing calls but I can hear callers voice for my samsung galaxy prevail . Voice memo works and phone is not muted
That means your microphone has in fault or lost its capacity to gain the sound. So you have to change your microphone. Thanks
Jun 26, 2014 | Cell Phones
HOW DO I PAIR MY MOTOROLLA H700 TO MY IPHONE
The H700 is a little picky when pairing.
Make sure the H700 is fully charged.
1. Leave the H700 Microphone closed and hold down the button until it turns purple. 2. Once the light is purple, open the microphone. (If it turns blue then start over. This is normal operation mode not pairing.) 3. Go into iPhone Settings>General>Bluetooth and turn Bluetooth on 4. H700 should appear on the screen. Select it. 5. If the device asks for the Device PIN, enter: "0000" 6. The two are now paired.
The H700 may leave pairing mode during the process. This is the pickiness I mentioned. If it does then just restart the process. It may take several tries or it may work on the first shot. Just be patient.
May 03, 2011 | Video Game Consoles & Games
My headset is working except for be able to hear me speak
There are no mute buttons for your bluetooth headset, your microphone must be blown off, try contacting service personnel, you will get it fixed.
May 24, 2010 | Motorola Mobility H700 Wireless Headset
Nokia E65 microphone doesn't work
hi thanks for using fixya!!
Did you accidentally dropped the Nokia E65? Well, on this error, you shoudl bring your unit to a service center to further check the hardware error such as the microphone. However, be sure that whenever you make calls you have the network signal high so that you can have quality voice calls.
If you need further assistance, let me know
May 26, 2009 | Nokia e65 Cellular Phone
Microphone isn't working on my hs850
You can mute outgoing voice during a call by tapping on both volume buttons and tap them again to un-mute.possible you are experiencing this . i did
Dec 06, 2008 | Motorola Mobility HS850 Consumer Headset
About my microphone
make sure your audio device is selected, the one that you are using such as a usb phone over your onboard realtek audio.
Aug 19, 2008 | Shure Head Set Microphone Microphone
How to hear my voice through my usb microphone?
by default the playback of your voice is muted. next to your clock theres the sound speaker icon click on it, you should see microphone somewhere there, if you dont press settings from the toolbar and then properties
then on the playback make sure there is a X on microphone.
then click ok, now check is the microphone muted? unmute it and speak to the microphone you should hear your own voice played back instantly from the speakers.
Apr 24, 2008 | Logitech USB Desktop Consumer Microphone
H700 Headset
Is the Samsung bluetooth turned on?
Jul 17, 2007 | Motorola Mobility H700 Wireless Headset
H700 headset can't hear me!
Push both volume buttons at once to turn Mute off. You should hear two beeps, ascending in pitch to indicate mute is off. If they go down in pitch mute is being turned on.
May 09, 2007 | Motorola Mobility H700 Wireless Headset
Trouble connecting h700 to phone
First: When charging the light should be steady. If the battery is less than 20% charged it should be red. More than 20% it will be yellow. Fully charged it should be green. Make sure your microphone is closed when charging.
Second: Have you "Paired" the H700 and the phone? If not you need to. To put the H700 into "Pairing Mode" do this:
Make sure the H700s microphone are is in the off position. Push in and hold the button on the H700 until the light lights up purple. Release the button and quickly open the microphone button. The light will stay purple and you are now in "Pairing Mode". Now follow the instructions for your phone to pair with a BlueTooth unit. When it asks for a code, use 0000 (that is 4 zeros).
Your phone and H700 should now be connected.
Hope this helps a bunch!!!
Jan 04, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
1,537 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
