Question about Motorola Mobility V635 Cellular Phone
Can not input text
I can not input test on my V635. Either text messages or assigning names to phonebook items. When I try to input text the phone freezes up for 2-5 minutes. Also the phone has been freezing up a couple times a day on me. Is there a fix for this.Thanks
You need to reset it to factory values
Posted on Aug 08, 2008
My motorola razr does not display the names when i receive text messages
check the phone book entries...possible the names are appearing twice in the phonebook...or the format in which nos are saved could be diff from the format of numbers u get message ...eg : u might have stores only no and when u recieve msg it might come with a 0 or country code too
Feb 11, 2012 | Motorola Mobility RAZR V3
1. I can't hear the ring tone when one of my contacts calls me. All others are fine. Help! 2. When I text, it automatically replaces words, not what I want. How can I remove the automatic feature?
Scroll through your contacts list, when you get to thet number in question, select details > contact name > assign tone > then select your ring tone and assign it to the contact.
For the text messaging, you are on predictive text input, and the upper left of your screen would have an UNDERLINED pen with either 'abc', Abc' or 'ABC'. Toggle your hash key until you get any of the UN-UNDERLINED pen with 'abc', Abc' or 'ABC'.
Hope that was helpful?
Have a lovely day.
Jul 12, 2011 | Nokia 1280 Cell Phone
How do you delete text messages from a motorola V635 mobile?
Hello i hope u 'll be fine.... thanks for using fixya.
It depends on the particular message you want to delete (might be from your inbox,outbox,draft,etc)
If u want to delete messages from you inbox
Go to the menu>>Click the message>>Go to inbox messages,you will see all your messages,You will see and options there>>Click on it and scroll you will see where they will be option as delete message.You can now delete.
When you open the rest too, there are all the same procedures.
I hope this solution will helpful 4 u. Best of luck
Please keep thumbs up in do rating
THANKS & Keep using fixya
Dec 30, 2010 | Motorola Mobility V635 Cellular Phone
When i recieve a text message the name does not appear on the screen of who sent me the text it just has text message. it never did this before and was wondering if it was just a setting change?
It does not seem to be a setting change.
Please ensure that you still have the person's name in your phone book.
There are times when a multiple entry will cause the name to not to be displayed.
Just check once and look at the first and the last entry of your phonebook.
The repeat number often gets saved in the end of the phonebook and has no name.
Since there are 2 numbers, one with name and one without... it causes a conflict.
In case you see repeated entries, delete one. Then please test.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Oct 21, 2010 | Samsung S8300 Ultra Touch platinium-red...
How do i get the t9 off my text messages on a samsung d900???
ABC, T9, Number, and Symbol modes
You can enter text in some features such as Messages,
Phonebook, or Calendar, using ABC mode, T9 mode,
Number mode, and Symbol mode.
Changing the text input mode
• Press the right soft key to change the text input
mode.
• Press and hold [ ] to switch to Number mode.
• Press and hold [ ] to switch to Symbol mode.
Using ABC mode
Press the appropriate key until the character you want
appears on the screen.
: ABC mode : T9 mode
: Number mode : Symbol mode
Apr 07, 2010 | Samsung SGH-D900 Cellular Phone
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
Delete top 3 text message recipents
Go into a new text message and hit the "send to" option. Scroll down to the first name above the line and hit the "options" button. Scroll down and select "Recent messages" and choose whoever from that list that you'd like to be your top 3. I actually just sent all three of mine a blank text, but when I went back to the "send to" list voila! MORE INFO: I tried all kinds of things to remove names from my top three recipients list. What ended up working was to send a text to multiple recipients at once. Two was enough. But it was important who I selected first. I sent a message to my wife and my friend. My wife's name got added back to my top three! Then I reversed and sent a message to my friend and to my wife. His name got added back!
Sep 17, 2008 | Samsung U900 Soul Cellular Phone
Lg viewty phonebook
When you are in the phonebook, click the options box at the bottom left (thing that looks like a little ladder) and scroll down to TEXT INPUT and change the INPUT METHOD to ABC mode.
Hope that helps,
Clare
Jul 01, 2008 | LG KU990 Viewty
Text messages
first thing i would do is to make sure you have the area code included in the contact entry.....this is most like the problem
Nov 10, 2007 | Motorola Mobility W375 Cellular Phone
Motorola Mobility V635 Cellular Phone Logo
43 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
