Question about HP Office Equipment & Supplies
HP psc 1210xi paper jam
My HP all-in one grabbed all the paper (it's humid) and it's jammed. I have a windows XP system. Thanks
Connie
I found out my all-in-one was not supported since it's old---but works well. Since the machine doesn't open up, I just gently tugged on the paper from the longest end until it came free. It does not seem to have suffered any ill effects and prints just fine, now.
Connie
Posted on Jul 24, 2008
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
Are there any releases for a paper jam in an HP psc 950? I have a paper jam that is under parts that do not appear to be moveable. I also cannot remove the paper tray--and my fingers can't fit inside to...
1) Power Off.
2) Disconnect USB cable and power cord
3) Clear the paper jam from the back of the unit by opening the rear access door. Turn the dial on the rear access door counter clockwise, and then pull the door toward you to remove it
4) Gently remove any paper from the rollers. Get all the pieces - any bits left inside will make it more likely to jam with future use
5) Reattach the rear access door. Gently push the door forward until it snaps into place
6) Reconnect the cables and power cord.
Try your print job again.
Dec 21, 2009 | HP PSC 950 All-In-One InkJet Printer
HP PSC 1210xi does not accept paper from the paper tray.
Remove IE8. Use add / remove programs. It will put you back to IE7 and your printer problem will most likely be gone.
Aug 05, 2009 | HP Office Equipment & Supplies
Printer jams
Check you paper and be sure it is dry. Sometimes if you are in any air condition areas the paper will get damp or if you run into this when the humidity level is high. Try storing your paper in a different room that is dry. Mine did the same thing after the temp changes outside. See if you can remember when it worked fine as to what time of the year it was. Did it work fine in the Winter for example and now in the summer it does not work.
Jun 02, 2009 | HP PSC 1315 All-In-One InkJet Printer
Paper jam
there is a assess door in the back of the printer to remove any paper jams.its removable , you can pull that door outside by rewinding that channel on the back.
thanks.
Oct 15, 2008 | HP PSC 950 All-In-One InkJet Printer
HP Printer not pulling paper
Check for a jam in paper feeder, look down back with a torch, open up unit and search inside, have a pair of tweezers handy as jams can occasionally be very minute and hard to grab.
Aug 30, 2007 | HP PSC 2175 All-In-One InkJet Printer
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
