Question about HP DeskJet 5150 InkJet Printer
HP Deskjet 5150 - top cover open
Error Message - "Top Cover Open".
I keep on getting this message when I want to print even though the cover is closed.
my e-mail address : bevanechardt@calsa.co.za
  • 1 more comment
  • gmossdesigns Jul 24, 2008
    I am having a similar problem.  I am not able to print, I changed the cartridge after the computer said that the cartridge was not compatible.  It was weird because i am using the correct and same cartridge I have been using for years.
    Please help.  Thank you,
    G
  • hofayyaz Oct 07, 2008
    i have this problem too!
  • Anonymous Mar 13, 2014
    close top cover, even if its closed ???
  • 3 Answers
I had the same problem, and the cause turned out to be the cover switch not being fully pushed in. On the underside right edge of the top cover, there's a little triangular protrusion that pushes down a black rectangular button (the cover switch) when the cover is closed. The problem occurs because the flimsy top cover is made of plastic and flexes slightly when you close it. This means that sometimes, the right edge of the cover won't seat properly even though it appears as if the cover is closed all the way. When this happens, the triangular protrusion isn't fully pressing the switch down.
To test if this is this is happening, send a print job to the printer and wait for the "top cover is open" error message to appear. Next, open the top cover door and locate the cover switch. It's a little black button in a rectangular hole at the right edge of the doorway near the ink cartridges. Take a pen or a car key and use it to push the cover switch down. You can also use your fingertip to do this if it's skinny enough. If you keep the cover switch pressed down, the power button should start blinking to indicate a print job is coming through. If the print job actually starts printing, then you know the problem was the cover switch.
In my case, all I had to do the fix the problem was close the cover and make sure it was fully seated by firmly pressing down the right edge of the cover until I heard a plasticky "click" noise. After that, the problem went away.
Hope this helps.
Posted on Sep 16, 2008
I want to instal printer
Posted on Oct 10, 2008
Disassemble
If you get this error:
Top Cover Open. The device cannot print because the top cover is open. Close the top cover and press continue, or cancel the printing.
then follow this guide:
HP Support document HP Support Center
Apr 06, 2012 | HP DeskJet 6840 InkJet Printer
When I try to print, I get the error: Top Cover Open: The printer cannot print because the top cover is open. How do I fix this?
Hi cduckyquack ,
  • All you need to do is close the printer cover if it's open , once it's closed you should be able to print correctly without any warning messages.
  • If the cover is closed and still you are getting the same message , then it might be a problem with the censor switch which indicates to the printer whether or not the cover is open, so if the switch / sense has gone faulty then you need to repair it.
  • Sometimes just because of dust the printer does not sense the cover being closed and it results in the error message that you have described.
  • Hope this helps ...) your feedback would be appreciated.
Jun 02, 2011 | HP DesignJet 1050c plus InkJet Printer
I keep geting the door open error message for HP Deskjet 3940. How can i fix this problem?
hi there!
make sure that the top cover of your hp deskjet is fully closed, open it up again, check for any obstruction then make sure you hear the snap sound when you close it back. if you're in the usa, you can contact 800-hp invent for technical support especially if the printer is still in warranty!
Apr 06, 2011 | HP DeskJet 3940 InkJet Photo Printer
My hp deskjet 5150 doesn't print. I get a message on screen that the lid of the device is open although it's not
On the right side of the printer's cover is a small plastic "v" shape piece, That piece activates a swith that tells when the cover is open.
With time that piece wears-out, so the solution is to replaced the cover or wrap that piece with scotch tape (one single turn will be enough).
Jan 13, 2011 | HP DeskJet 5150 InkJet Printer
Getting message Top Drawer Open-will not print
the sensor that allows the printer to know when the drawer is open or closed could be broken. You may need to have your printer looked at by a technician or if you can locate the sensor either remove it or see if it has come out of place.
Jun 04, 2010 | HP DeskJet 5652 InkJet Printer
Says can't print because top cover open when it's not. Tried resetting by pulling plug, re-opening and closing top cover.
this is the common problem of 5150 printer .you just open the top cover ,in your right hand you can see a black moving part it may not working properly. try to move back and forth many time ,then close and check your printer.
Feb 12, 2010 | HP DeskJet 5150 InkJet Printer
Error message top cover open
When the printer is used often, and ink and dust accumulate inside, the detector switch will sometimes get stuck and won't be depressed by the cover correctly. Open the cover and look right next to the sticker. There is a small rectangular hole with the switch. Use a very thin tool like a small screwdriver or paperclip bent open to push the switch inside the hole to the back of the printer. Do NOT push it just down! You *must* move the switch away from you. Hold the switch in this position and close the cover. Carefully pull out your tool from the gap.
Jan 28, 2010 | HP DeskJet 5652 InkJet Printer
I just changed my printer cartridges and I'm trying to print but I keep getting "door open" or "top cover open" message and nothing prints. My printer is a HP 5150
Open the cover.In right side you'll see the cover sensor.It's a plastic lever, which does down to the bottom of printer.The top side of this lever usually breaks.
Oct 13, 2009 | HP DeskJet 5150 InkJet Printer
I recently replaced the magenta cartridge in my HP 3210 Photosmart printer because the light indicated it needed to be replaced. However, the printer still won't print, and the message still says that I...
If you turned the machine off and replaced the cartridge, you can get this error.
Could you try the following procedure below please to clear the error, thanks.
  1. Turn on the unit.
  2. Open the top cover to access the print cartridges.
  3. Remove the new cartridge that is causing the message.
  4. Reinsert the cartridge and close the cover. The following message will appear on the front panel: "Press 1 for new cartridge or press 2 for a used cartridge."
  5. Press the 1 on the numeric keypad of the HP product.
If the message, press 1 for new cartridge or press 2 for a used cartridge, "does not appear after removing and reinstalling the new cartridge, and the low ink warning message still displays,
follow the steps below:
  2. Open the top cover to access the ink cartridges.
  3. After the cartridges stop moving, unplug the power cord.
  4. Remove both cartridges and close the top cover.
  5. Plug the power back in. The unit will reinitialize and a message will appear to insert the cartridges.
  6. Open the top cover and reinsert the ink cartridges. Close the top cover. The message,
  7. Press 1 for new cartridge or press 2 for a used cartridge," should appear.
Hope this helps
Regards.
Apr 18, 2009 | HP Photosmart 3310 Printer
Top cover open error when printing
I had the same problem and fixed it by sticking the end of a pen (the writing part) in the hole on the right side when you open the top cover.
In other words if you open the top cover and look on the top cover you will see a tab that goes into a hole(the hole is next to the picture of the print cartridges). There is a hole with switch/tab(I don't know the proper terminology) on it that is activated when you close the top cover. If you stick the end of a pen in that hole it should activate something and the print cartridges will start to make noise and move around. You can then close the cover and it should close all the way.
You can then try to print a test page.
Good Luck
Dec 13, 2008 | HP DeskJet 5650 InkJet Printer
HP DeskJet 5150 InkJet Printer Logo
2,745 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
