Ff 301 keyboard error - Computers & Internet
  • Anonymous Jan 03, 2009
    I have this problem too. I Think there is some sort of a conflict going on or a harware problem. There isn't much info in the bios. Everthing seems auto configure (or on/ off). The funny thing is, on a clean boot, that is when the problem crops up. But if I update the intel chipset driver (and it reboots) the problem goes away until the next fresh boot. Then I have to re-install the chipset drivers again to clear the problem. My guess is that it's either XP, IE7 or the actual eMachine harware. Is anyone aware of there being any "known system bugs"?
    Sergeant:
  • 313 Answers
1. This can happen if you have the mouse and keyboard plugged in the wrong ports. Can you double-check you are plugging the keyboard into the correct port.....
2. several keys pressed simultaneously
3. key on the keyboard is stuck (try a different keyboard and see if you get the same error.
Posted on Jul 23, 2008
Error code 301-0001 on i-sensys MF 4450
Show error code 301-0001 after press (Problem with Canon i-SENSYS MF4140 All-In-One Laser Printer
Error code 301-0001 on i-sensys MF 4450cont: 8016185745-dulal
Nov 27, 2012 | Canon i-SENSYS MF4140 All-In-One Laser...
Smart disk error 301
Anytime the Error 301 messages appear on your computer, it is due to corrupt or damaged system files.
If you do not fix this error immediately, it can lead to additional system issues, blue screens and hardware problems.
Frozen programs, installer errors, random shutdowns, system freezing and sluggish computer performance are common symptoms of the Error 301.
Fortunately, you can fix the Error 301 with features native to your computer.
Click "Start" and then "Computer." Right-click "C" and select "Properties."
Select the "Tools" tab and click "Check now." Select "Continue" if the User Account Control prompt displays.
Select the "Automatically Fix File System Errors" option and click "Start." Agree to reschedule the check for the next system restart.
Reboot your system.
Allow the check disk to detect and repair all Error 301 issues.
you should have no input while chkdsk utility is in progress any input might further damage your computer it might take some depending on the size of the disk be patient.
Hope this helps
Oct 28, 2012 | HP 500 GB SATA Hard Drive
Error 301 on IBM 600x
HelloThe IBM error 301 POST code means the keyboard is not responding correctly. Folowing may be the reasons:-
  • You could have a stuck key, or the keyboard cable is faulty and not making proper electrical contact.
  • You could have a faulty keyboard controller.
  • You may have a faulty keyboard which may had some fluid spilt on the keys.
  • Try clean and reconnect the keyboard cable.
If this doesn't work try connecting an USB keyboard and see if this keyboard functions correctly.
If none of these work you have a motherboard problem.
Good luck, and do rate the solution if got help
Dec 08, 2010 | IBM ThinkPad 600X Notebook
I got these error messages: 301 and 8611. What does these mean and what I can do about it?
IBM errors 3xx are usually the keyboard problem. 86xx are usually mouse/pad/etc problem. Check for cable connection.
May 30, 2010 | IBM ThinkPad T30 2366 Notebook
Error code eo 301 ibm thinkpad301
keyboard error. Reseat the keyboard connection. If no resolve, replace the keyboard
Aug 09, 2009 | IBM ThinkPad 600X Notebook
Error code 301
If none of these work you have a motherboard problem. The Thinkpad 600 is a very old laptop and it would not be worth fixing. I suggest putting your money towards a new laptop.
Jul 12, 2009 | IBM ThinkPad 600X Notebook
What is a 301 Keyboard Error and how do I correct this problem.
The motherboard has device controllers that read id #'s of your hardware. When a device fails, a fail code is thrown out which is attached to the device id. Sometimes when en error has been cleared the code for that device may not. Try to boot the computer with the mouse removed & a different keyboard. Shut down & install the mouse & original keyboard. Let me know what happens
Sep 29, 2008 | Compaq Computers & Internet
IBM keyboard not recognised, had 301 error, reser cmos and battery. only error message now is date/time, but can't scroll on setup screen as keyboard still wont work, tried other keyboard
Try a Microsoft/Windows update and look for the hardware update ( select Hardware updates on the left side of the page) to see if there is one for your keyboard. It may fix your problem?
Jul 19, 2008 | Computers & Internet
Error Code 07 301
With IBM Thinkpad,it telling you that some hardware is faulty, check your keyboard to make sure nothing is stuck. Also it could also be your trackpoint. Usually, replacing the damaged part gets rid of the error! However there is a bypass key sequence that allows your to continue booting the system even though it gives you error. I'm not 100% sure of what it is but somthing like ESC at boot or F1 or maybe your need the boot to the error page then press ok, then when the system comes up again press f1 or esc then. You'll have to play around with the key sequence a bit. But to get rid of the error forever you need to replace the damaged part! Regards, Armando
Apr 28, 2007 | IBM ThinkPad 600X Notebook
Computers & Internet Logo
671 people viewed this question
David Payne
David Payne
