FixYa.com
Tags:
Brookstone Pure-Ion UV Air Purifier
Brookstone Pure Ion Advanced (by 2 users)
posted by jrinorlando on Jul 23, 2008
I have cleaned filters, plugged unit in, and simultaneously inserted the filters in place firmly. Switch will not turn on, but holding the on/off switch down while randomly touching the other touch switches, I can get the unit to turn on in the turbo mode, with the run program light on. When on in this mode, no switch will work at all, not even the on/off switch. I have to unplug it then to turn it off, and go through the same semantics all over again to turn it on. What do I need to do to really re-program or re-set this unit? Thanks a LOT!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by ssobel3038, posted on Aug 15, 2008
I am having the exact same problem. How do I fix it?
Can you Help with these Air Purifiers problems?
Brookstone Pure ion uv air
you said it has two filters... Answer This...
Brookstone Pure Ion Advanced...
I have cleaned filters, plugged... Answer This...
It clicks when I plug it in,... Answer This...
uv germicidal lamp out
Where can I find a new... Answer This...
Repair Service
Find Air Purifier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
