Question about Refrigerators
GE model TFX27 ILB 26.6 cubic ft.
The refrigerator side of the unit isn't getting cold enough.
dididsaythat
  • 291 Answers
SOURCE: Ge refrigerator not cold enough
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting,
Posted on Sep 12, 2007
MNTECH
  • 1543 Answers
SOURCE: cubic feet?
Most refrigerator models with two digits, the rest letters, the digits stand for the cubic foot capacity of the refrigerator. In you case, 23 cubic foot model.
Posted on Sep 16, 2008
SOURCE: Not cold enough
I opened the bottom panel at the back of the fridge and cleaned the coil because it was completely covered with dust and lints and less than an hour later the fridge side temp started going down and the freezer took five hours for the temp to start going down when we didn't open it for that much time. It's back to factory setting now and thanks for the blogs that I read that I was able to try different possibilities. Your site is very helpful.
Posted on Mar 21, 2009
SOURCE: Water interior of fridge....GE profile 21.6 cubic ft. model #TBX22PIYMRBB
i have this problem .whats the fix
Posted on May 29, 2009
  • 24 Answers
SOURCE: Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Posted on Jul 28, 2009
What is the cubic ft size of my GE Refrigerator?
On the inside wall of the refrigerator there will be a model number for unit. Usually the model number indicates the cubic size of unit.
Jun 12, 2015 | GE Refrigerators
Need the cubic ft for a year 2000 GE
Do you have a model number?
Jan 31, 2015 | Refrigerators
I have a GE tfx27 or 25pp side by side fridge. Neither the fridge or freezer are getting cold. Fan in freezer is running, condenser runs. Any help?
is the large side of the tube coming from the compressor pump very cool /cold.
is there fuzz in the coils . does the fan to the compressor work always , in the bottom back under the cover
Aug 03, 2014 | Refrigerators
Could you please tell me what the cubic ft is overall on this refrigerator? Thanks.
A standard top mount freezer from sears is 18 cu ft, a little bit larger is a 19 cu ft, then 21cu ft, and then 22, 25, and 26 cu feet for side by side models. How did I do without your make model or anythang to go by? LOL
Jul 16, 2011 | Refrigerators
I'm unble to determine what the cu ft is for my GE side by side. Model # TFX24RHB. Can someone help?
It's typical of GE to have the cubic footage in their model number, so yours should be 24 cubic feet.
Mar 27, 2011 | Refrigerators
How many cu ft is it?I have a tfx25zpbeww
The number in the model number is the cubic foot size. In this case, between 24.5 and 25.4, so it is called a 25 cubic foot model.
Jun 19, 2010 | GE Profile 21.6 cu. ft. Side-by-Side...
Refrigerator cool freezer not as cold as it should be
try turning of the frige and let it be of for 1day then put back on and see if will works usally does,if not next usally is the compressor does give enough cold.motherboards dont go bad usally very rare,check all the above before you buy motherboard.please leave comment,vote,note.thankyou
Sep 13, 2009 | GE Energy Star 22.0 Cu. Ft. Side-By-Side...
GE Side by Side refrigerator and frezzer not cooling
FIRST MAKE SURE YOU HAVE IT SET TO DIVERT MORE AIR TO FREEZER SIDE THAN RE FRIG SIDE , MAKE SURE THERMOSTAT IS SET TO COOL ENOUGH , NEXT MAKE SURE SMALL FAN IN REAR OF FREEZER IS RUNNING , SOME MODELS YOU MUST DEPRESS DOOR SWITCH AS YOU WATCH IT , IF FAN IS BAD YOU CAN REPLACE IT YOURSELF REMOVE FAN AND COVER AND MOST UNPLUG , SOME IDEAS
Feb 23, 2009 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
133 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
