I am getting an F02 error on my whirlpool duet washer. I have taken the drain hose off all the way to the pump and cleaned it out but i am still getting the error code. Also get the SUD code after i clear the error and continue.
  • Anonymous Apr 27, 2009
    I have the same problem. When the unit is cycle to the spin/drian cycle, it will sit there vibrate but does not spin then the F02 message is display and beeps.
  • 5,911 Answers
Please click on the following link and follow the advice for attempting to clear this error:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
If you have tried all these procedures, then it is recommended that you replace the drain pump. If you need procedures on how to replace the pump, click on this link:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Please note, in some circumstances the drain pump WILL run, but still does not pump correctly. This could be caused by an impeller that is damaged or stripped. If you require further assistance, please post back and let me know. I hope this helps you.
PS The SUD error would be in direct relationship to a pump failure and/or clog somewhere in the drain system.
Posted on Jul 23, 2008
What is code message F02?
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 09, 2014 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Sep 06, 2014 | Whirlpool Washing Machines
My whirlpool duet washer had a F02 code now it won't pump water
Aug 24, 2014 | Whirlpool Washing Machines
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet flashes F 02
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch. Ensure the hose is clear by blowing into it. If the hose is clear I recommend replacing the pressure switch.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F02
I have a Whirlpool Duet. I am getting an F02
You may need to disassemble all the hoses and inspect everything problem maybe a partial block? It can still drain but if it is slow and takes too long you will get the F02 error.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F-02
Please read the following link. This explains what to do if you get the "F02" error code.
If cleaning the drain hose is not clearing the problem for you, then you need to check the drain pump and/or the drain hose from the wash tub to the pump. These areas are notorious for clogging with debris.
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
