I have a Magavox television and the channels will not show . All channels are fuzzy. It will get only numbers starting with channel 49. I need to do a channel search to get all the channels to show.
have a magavox tv combo, with dvd and vcr. It will not stay on unless you put a tape in and spend 30 minutes to an hour turning it on and it goes off automatic. Less than two years old.
Posted on Mar 26, 2009
How do i set up my tv with my sony vcr
Hi Katie.. If you are using a coaxial cable to connect your TV and VCR, the TV needs to be tuned to channel 3 or 4. If you are using the Yellow, red and white cables, your TV should be on video mode to work.
Sep 14, 2015 | Toshiba 24AF42 24" TV
Fuzzy picture
Sounds like an AGC [Automatic Gain Control] problem with its video IF stage circuit. Contact any service technician, or service center. This is not a user repairable fault.
Gopakumar Gopalan Google
Feb 09, 2014 | Sony FD Trinitron WEGA KV-27FS100 27" TV
How do I change channels on my Maxon 49-sx
  • The "Maxon 49-SX" is a single channel transceiver that only operates on 49 MHz FM. The Maxon "49-FX" and "49-HX" operate on 5 adjustable adjustable frequencies. That radio has no channel/frequency options.
  • Hope this helps.
Nov 18, 2011 | Maxon 49-SX (1 Channel) 2-Way Radio
How do I get the picture?
The TV is usually set to Channel 3 or Channel 4. You may have a switch on the back of the VHS recorder near which is marked Ch3 Ch4.
Once you correct this, try the following procedure.
Some VHS have a tracking button that allows the user to tune to the best signal. The tracking can also be done from the remote controller.
Usually that tracking function is used as follows.
While movie is playing on the VHS unit and signal gets fuzzy, press the channel key repeatedly (for example >> to increase the channel number). f after awhile pressing the same channel change button does not find a better picture, you should press the other channel change button (to decrease the channel number <<) to see if the picture improves.
If that does not work, IT DOES NOT MEAN that you tv/vcr combo unit is defective. It could just be the movie. The tape is magnetic and it might have been accidentally demagnetized.
If picture is better with another movie/tape, your unit is definitely OK.
May 20, 2010 | Memorex MVT2135 13 in. TV/VCR Combo
Channel numbers change but channel does not
The problem is in the "Guide-Plus" set-up. Go theu the set-up process again and when it asks you if you have a cable box select NO.
May 25, 2009 | RCA P61960 61" Rear Projection Television
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
TV Color
You need to replace both convergence ICs they are both STK392-120 and you will also need four 6.8 ohm 1 watt metal film resistors. You can get the ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Here is the link.
http://servicemanuals.vstore.ca/
Jul 04, 2008 | Philips 60PP9202 60" Rear Projection...
Television stays on one channel
You likely have bad solder connections in the tuner.
Jul 12, 2007 | Sony KV-35V75 35" TV
Snowy picture on certain channels and only sometimes
Hello, the best option for you is to put another (small) TV instead of plasma to check whether your cable is OK. If you need more info please advice. Arpi
Mar 16, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
