GE Spacemaker JVM1640SJ Microwave Oven Logo
Posted on Feb 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE spacemaker mircowave not heating- all else works ok
Anonymous
Level 3:
  • GE Master 43,501 Answers
  • Posted on Feb 22, 2011
Anonymous
GE Master
Level 3:
Answers
43501
Questions
0
Helped
10835259
Points
101584
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mircowave heats propperly, but clock goes blank
Possible fault with your timer controller unit processor board. In many cases insects can cause secretion and so the clock circuit can malfunction. remove the unit and use a air cleaning. heat the board if there is presence of moisture.
1helpful
GE Spacemaker Microwave #JVM1650WB008 is not heating.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
2helpful
Mircowave turns on but does not cook food food does not get hot all other options on oven work fine
you have a bad magnetron . that is the heating source . the part is not cheap. go to sears parts direct and check out the price b4 you have someone check it.
GE Spacemaker shuts off after a few seconds and asks for the clock to be reset
Ge Spacemaker comes on ok but after a few seconds the noise level goes up significantly and it does not heat. It keeps running until the time runs out but it doesn't heat.
4helpful
In model spacemaker xl1800 no heating but all
heatman101
gfj
11helpful
Spacemaker XL1400 GE Microwave
my xl1400 spacemaker ,it just won't heat, everything else works
ok, can you all advise me what to do, what could be causing it to not heat.
wendell
1helpful
Mircowave will not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
My GE Spacemaker Microwave is not getting enough power
the dimming of the light indicates a big amount of current being drawn by the magnetron. can you see sparks inside the oven?..it looks like the magnetron is shorting out with the ground. what makes it short to ground could be in the wave guide cover...look for some dark spots or accumulation of carbon from old food residue which becomes carbonized due to repeated heating. carbon is a conductive material that shorts the magnetron to ground.
i hope i was able to help
JVM290
The interlock switch is badly adjusted or worn.
Remove the case and adjust the switch.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
