Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Dispenser Board Is that the same as a HV Control Board? Can it be replaced and are they readily available or is this something they'd have to order in? Thanks for your help in this matter! I don't see my fridge listed but it is model number 57677535600.
  • 93 Answers
You must have a Kenmore. You can go to searsparts.com to get sears part number. HV board is not the same as dispenser board.
Posted on Jul 23, 2008
I have a GE gss25tgp, I was hearing noises earlier now i just went back to the fridge and now the water dispenser and ice dispenser aren't working would that be a control board issue?
The dispenser control board is fed from the main control board located in the back. The main control is usually the root of most problems .Order from repair clinic if it does'nt work they will take it back.
Dec 05, 2016 | GE GSS25TGPWW / GSS25TGPCC Side by Side...
I have a zfsb26dnd ss GE Monogram with a Dispenser board dead. ordered a new board and same result, ordered a new main control board and still nothing has changed. what else could I check or change?
You changed the main control board---is that the main mother board on the outside back wall of the refrigerator???? If not then the mother board may need changed. Part number WR55X10942. Just about every part of the refrigerator operation runs through that board. If you did change that already I would look for possibly a bad wiring connection to the dispenser system. There is usually wiring and plugs going through the hinge area of the door with the dispenser in it. some are at the top hinge some at the bottom depending on model number.
Jun 10, 2015 | GE Monogram ZFSB26DRSS Stainless...
Water dispenser doesn't turn on when water button is pressed and also turns on randomly even when its not pressed. Sometimes the water doesn't stop even when the door is open. It also sometimes says the...
The problem could be several things that you will need to consider. The=> W10267646 Control Board or here=> W10267646 Control Board The door switches and the dispenser control board=> W10271914 Dispenser Control or here=> W10271914 Dispenser Control Finding what is causing this will be tricky so I am here if you would like me to help you tackle the electrical diagnostics that is causing this problem. If you would like the service manual and assistance please let me know. Repair Clinic will let you return items not used in the repair, Sea Breeze
Oct 10, 2013 | Maytag Refrigerators
The control panel on the door where I select ice or water will not let me select between ice or water. The lights are off on both and when I press either all of the other lights turn blue or red.
If you have no control at the dispenser, you will need to replace the HV control board. Here is the board to order.
Once you replace the board it will need to be programmed. The Program Code is located on the Serial Plate on this unit after the word Code.
Nov 08, 2012 | Whirlpool GI5FSAXVY Stainless Steel ...
Blinking board and flapping ice dispenser.
We called Maytag customer service and they resolved our problem and is sending us a new control board and sending out a technican to our home to install at no charge! What great service! Thank you Maytag!
Jun 11, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
The piece of **** we own is pt# r-1500. In less than a year the lcd display shut down. Now the switch assembly has broken and we have been informed the entire control panel assembly is unavailable. Nice...
Both parts are readily available - you can order them from Martin Microwave Inc.
(toll free 1-877-894-0035).
The lcd / control board / display is Sharp part # CPWBFB075MRU0 and it sells for $79.99
The button assembly is Sharp # JBTN-B122MRF0A and it sells for $13.99
You can also check with www.microwavedisplay.com for a rebuilt board
Sep 10, 2008 | Sharp Microwave Ovens
We have a french door botom freezer maytag w/ and electronic water/ice dispenser. Model #mfi2568ae In the middle of the night the ice dispenser started opening and closing by itself and the led display is...
Don't be duped into thinking the display/dispenser board is the culprit. It may come a surprise, but this failure is often misdiagnosed. Because the dispenser is causing such a ruckus or because the display itself is blank or flickering, folks are led to believe that the display control board itself is the part that has failed. Looking at the history of our board evaluations, this little tiny control board rarely fails. And as crazy as it may seem, it is the main control board, aka the high voltage control of the fridge that is causing your refrigerator not to cool and the dispenser to be erratic.... This is the main control board of the refrigerator, located on the back of the unit. I've attached photos of what this main control board looks like. This main control board will need to be repaired to replaced.
http://blog.fixyourboard.com/2016/06/08/ice-dispenser-flapping-display-flashing-on-refrigerator/
Ice Dispenser Flapping and Display Flashing on Refrigerator
Aug 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Remote control
Go on ebay, replacement remotes are $25 and are readily available.
May 26, 2008 | JVC RV-B99GY Cassette Boombox
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
69 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
