Question about Whirlpool 24 in. DU915PWP Built-in Dishwasher
Whirlpool dishwasher wont turn on, no lights, nothing.
The door was slammed shut by my child and now it doesnt work. Thanks for your help!
  • 487 Answers
It will be your door lock assembly
HERE are the drawings and parts of your machine
Posted on Jul 23, 2008
Is there a fuse on the Whirlpool 24 in. DU910PFG Built-in dishwasher? ... it just stopped working!
Good evening, There is no fuse that would shut down everything.Check for switch under sink or your home circuit breaker.Then it could be your door switch which shuts every thing down .It may be stuck open.Sometimes a door slam will get it going but still needs replacement.$40 part though.Switch is located behind console and can be checked with ohm meter.Sears Parts Direct shows blow up of your machine.
If it was your circuit breaker and it blows again ,you have a short and you'll need tech. to troubleshoot or maybe there is another load on that circuit (like toaster etc)
hope this helped
Aug 16, 2011 | Whirlpool 24 in. DU910PFG Built-in...
Have a whirlpool dishwasher and water standing in bottom
Hi!
Please check and make sure handle link is properly seated in door latch assembly and then check that the door switch is opening and closing properly.
Check the child lock, if it is “ON” then turn it "OFF"
Review setting of wash cycles as per the instructions given in the User/Owner manual.
Now check the circuit breaker or fuse.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 06, 2009 | Bosch SHV4803 Dishwasher
The dishwasher won't turn on
sounds like a problem with the door iterlock switch most of them have a small micro switch when you shut the door it activates the system quite easy to do but can be a bit fiddly
Mar 11, 2009 | Frigidaire Dishwashers
Whirlpool dishwasher stops midcycle and control panel goes blank
and the controls dont advance? to the end of cycle?
Feb 26, 2009 | Dishwashers
Child lock shut off
Hold the button with the lock until the light turns off. Consult the manual.
Can you provide a model number?
Feb 18, 2009 | Dishwashers
Fridge has problems
sounds like the defrost clock may be going bad and or a door switch. Look for a hole that has whatr looks like a big screw that you can turn.
Oct 21, 2008 | Frigidaire FRS26R4A Side by Side...
Door won't latch, interior light stays on, dryer will not start
it appears that someone bent the door or the hinge. that is my first guess.
Sep 22, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dishwasher will not turn on/ start cycle
i would ck incoming power at hook-up behind the lower access panel. maybe a wire nut loosed, if power present there next i would check the door latch switches, if they are not making contact with striker, or switch has gone bad, the machine is not recognizing the door closed and will not operate
Mar 09, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Whirlpool g2p dwi
either the latch thats on the door is bad,,or the catch on the tub is out of line,,,now if the dishwasher door drops hard and wont stay up ..you need new door spring and the weight makes it pop[ open..
Feb 17, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Dishwashers Logo
651 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
