Question about Uniden DCT646-2 Cordless Phone
DCT646 flashing Welcome Please Wait...
Had these a couple years and the charge indicator in the base looks good, and in the base the phone shows caller ID of inbound calls. But none of the keypad buttons work and when I remove from base (i.e. to answer) it just flashes Welcome! Please Wait... and I cannot get even to the menus. ANy suggestions would be welcome. I don't think I have bad batteries, and in the base if I hit a key same Welcome Please Wait message. Do not know how to reset.
I replaced with a new battery and mine started to work ok
Posted on Oct 05, 2008
I am trying to register my panasonic kx tga641es to the base. I have no instructions/user manual...can anyone help please???
I have similar model and setup should be the same..
1, Handset: press Menu
2, Handset: scroll using up/down arrow keys to "Initial setting" then press soft key Select
3, Handset: scroll to "Registration" press soft key Select
4, Handset: sroll to " HS Registration" press soft key Select
5, Base Unit: Press and hold (LOCATOR/INTERCOM/TRANSFER) for 3 seconds. The Charge indicator flashes. After the CHARGE indicator starts flashing, the rest of the procedure must be completed within 1 minute.
6, Handset: 1: press soft key OK
2: wait untill a long beep sounds and the display shows the new extention number
**Registration should be complete**
Aug 25, 2011 | Panasonic KX TGA641ES 1Line Cordless...
HEY, Just got DWX207 and it's not working. It's been charging for 48 hrs. and when you pick it up off base it is dead. I did push in the button on base firts. On base it flashes Welcome Please Wait
When you got it do you take the back off to make sure the battery is plugged into the phone? if yes! the phone clearly has a manufacture defect and should be returned.
Mar 24, 2011 | Uniden DWX207 1.9 GHz 1-Line Cordless...
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
One handset gives the message, blinking, Welcome!
I replaced the battery. It solved the problem.
Dec 20, 2009 | Uniden DCT646-3 Cordless Phone
Phone continues to display "welcome please wait..." I can't turn it off and I get no dial tone.
I have found this is cause by one of two problems: 1) the transfer button has been hit and it is waiting for anther unit to pick up. 2) (and most likely the problem) the battery is low on charge.
with case number 2 if your battery is at the end of it's life it will only keep a charge for a short time. it might even say it has a full charge but it does not. I have tested this out by switching the battery and then finding that the handset works fine. I hope this helps you.
Jul 13, 2009 | Uniden DCT646-2 Cordless Phone
I have problems the no link to base with Panasonic
  • Press and hold the LOCATOR/INTERCOM button for the extension that is displaying "No Link To Base" on the Base until a beep sounds.
  • Press and hold the FLASH/CALL WAIT button on the Handset that is displaying "No Link To Base" until a beep is heard.
  • When registration is complete, a beep sounds from the handset.
  • Wait for 20 seconds after registration is complete to allow the handset to establish communications with the base.
If this doesn't work or it keeps happening, replace the battery in the handset.
Apr 14, 2009 | Uniden DCT646-2 Cordless Phone
Phone says ''Welcome ... please wait'' when you try to use it
I tried to copy and paste the solution for this issue, but Fixya only allows so many charecters and I guess the answer is too long.
Go to http://www.uniden.com/index/manuals_results.cfm?cat=1
and select the owner's manual for your model phone. Follow the procedures for deregistering the handsets and then resetting the base. then re-register the handsets and you should be good to go. It is all pretty easy, just a little to wordy for this forum I guess.
Apr 04, 2009 | Uniden Cordless Phone
Uniden DSS7855+1, flashing ''welcome! please wait...'', wont work
This is not a direct solution to your problem, but a workaround for a similar situation. I have two headsets and two charging stations. One of the headsets was stuck with the message ''Welcome! please wait''. When I put the phone on the charging station it usually sits on nothing would happen, but when I put it on the other station the phone came back to life. The non-working charging station will still charge the phone so it is worth keeping.
Mar 04, 2009 | Uniden Lands Phones
Uniden TRU8885-2 Restarts every time an incoming phone call, start showing the Welcome message ....
YOUR batteries are bad and not giving full current to phone.Clean charging contact and see battery gets full charge. IFthe battery indicator will show full charge due to voltage but once if you remove battery and put it again indicator will be minimum. then replace batttery.
Oct 07, 2008 | Uniden TRU8885-2 Cordless Phone
I need to reactivate my uniden cordless phone with remote extra handset. It was on a second phone line in my home, and that phoneline has been cancelled. Now, both units are charged, but and plugged into...
This should get the job done for you!
To re-register DXA14588-2 handsets:
  1. Pick up the handset from the base. Press and hold [find handset] on the base.
  2. While holding [find handset], place the handset in the base. The charge/in use LED on the base begins to flash, indicating the base is registering the handset. Wait for at least five seconds.
  3. Pick up the handset from the base and press [talk/flash]. If the display shows TALK, the handset is registered. If not, place the handset in the base to try again.
  4. Press [end].
  5. Place the next handset in the base and wait for at least five seconds. No need to hold [find handset] this time.
  6. Repeat steps 3 - with any other handsets you have.
Please let me know if you have any further questions.
Good Luck!
Aug 11, 2008 | Lands Phones
Uniden DCT646-2 Cordless Phone Logo
3,093 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
