Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Turn signals My turn signals quite working the other day . Both sides quite at the same time and don't even burn. Allother lights are fine. Is this a bad flasher?
  • 1 more comment
  • Anonymous Aug 29, 2008
    My blinkers will come on but want blink and then you try them again later and they work. I have reg bulbs in front and LED in rear. This is on a 2000 Fat Boy
  • WILL101 Nov 21, 2008
    AAT TIMES MY LEFT TURN SIGNAL WORKS FINE.THE NEXT TIME IT WONT.THE RIGHT ONE ALWAYS WORKS FINE.NO BULB IS BURNT OUT.
  • Anonymous Mar 26, 2014
    my parking lights on driver side compleatly stoped working,my tail lights and break lights on driver side compleatly quit working and all four turn signals quit working all at once what is the problem
    Genius:
  • 2,028 Answers
Bad signal relay.
Posted on Aug 06, 2008
Turn signals don't work in my 2000 Nissan Xterra. Fuses are OK
Could be a bad multifunction switch or even the flasher relay
Apr 19, 2013 | 1999 Volvo S80
I have a 06 poniac torrent with left side signal trouble. Im the mornings and off and on thru the day the left signal light on the dash stays on. Signal wont work on the car, then when light in dash is...
You have a Burned Out Bulb on the LEFT side or the FLASHER has gone bad *(YES, it can only effect one side). It also controls the BLINKERS and FLASHERS TOO
Apr 09, 2013 | Cars & Trucks
2002 Pontiac Montana, electrical short Maybe?
I assume that you have checked the signal lite flasher.no other ideas
hope it helps
Regards
Mar 14, 2013 | Cars & Trucks
Signal lights don't work
Soudn like a problem with the turn signal FLASHER go to bad. Check location under the drivers side of the dashboard, look for a round silver disc that has prongs on the back .It is attached to the fuse panel and it is directly above the brake pedal mounted to the right of the steering column.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Dec 19, 2011 | 2002 Pontiac Sunfire
Turn signals on my 1992 Park Avenue blinked slower and now donot work at all. My emergency flashers work fine and all blink but I have no turn signals and nothing lights up when signal is left or righ
About your 1992 Buick Park Avenue 3.8L SFI OHV 6cyl. the Flasher is located:
Hazard flasher: Front seating area, driver side, under dash, mounted above kick panel
Turn signal: Front seating area, driver side, under dash, driver side of steering column, mounted on support bracket
Thank you for using Fixya, and have a nice day.
Nov 11, 2011 | 1992 Buick Park Avenue
Turn Signals quit working
Sounds like the turn signal flasher is going bad. The easy way to find wher the flasher is hidden is turn the turn signal on and find the clicking, that is the flasher. The emergency flashers work fine because they use a different flasher.
May 05, 2010 | 2000 Audi TT
What could cause my right front turn signal to not work some of the time. The bulb was checked and even replaced but did not solve the problem. Each time the car is turned off, the signal will work for a...
Some of th intermitent problems with lights can be traced to bad ground connection since flasher bulbs draw quite a bit of current. Some cars use the car bodywork as the ground connection. If the rear lamp flashes faster than normal when the front one does not you have a bad connection. Check the bulb holder and the ground connection.
Nov 24, 2009 | 2003 Land Rover Range Rover
Front driver turn signal quit. changed bulb, worked for short time, then quit. bulb OK. passenger side quit 1-2 months later. bulb OK. neither front emergency flasher work. automatic daytime front lights...
Check for head light (daytime)relay to be bad,this might have to do with the turn signals also,if the turn signals on this car,also have running lights in them,If this relay is not bad,replace the body control module.
Nov 07, 2009 | 2005 Pontiac Grand Prix
Blinker dont work flasher and other lights work
The turn signals don't work, but the emergency flashers do? If that's the case, replace the flasher, you have 2 flashers, one for emergency (hazard) flasher, and one for the turn signals. It should be on the fuse block under the dash.
Oct 23, 2008 | 1995 Jeep Cherokee
Lands Phones Logo
236 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
