Question about SanDisk Sansa e250 MP3 Player
Sansa MP3 player e250
I have a Sansa E250 player. When I connect to my comp thro' USB port it gets only charged. The drive does not show up. SO I cant manage files. My OS is XP
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Aug 14, 2008
My sansa player does not play.. It will not charge completely. When inserting it into the computer the screen says connected but it never fully charges.
Most Sansa require a high-power USB port in order to charge. Try connecting it to one of the USB ports on the back panel of your computer.
Jan 27, 2010 | SanDisk Sansa e250 MP3 Player
Tip
My sansa e250's USB port dos not shows up on MY COMPUTER/ON DRIVE :F and when i...
One of the typical problems people run into with MP3 players is that they lose the software that came with the player and can't figure out how to get music on or off the player. So here's a quick how to. This will work with most brands of MP3 players, or even USB flash drives.
First you need to plug it in to the USB port, if you are running anything newer than windows 98 you won't need a driver. Double click on my computer and it shows up as a removable disc(usually drive letter f:), double click this drive to open it as folder. This folder will show you all directory's and files on your player, here you can delete any songs on your player by finding the file and deleteing it. From here you can also put your music onto the player by copying and pasting your music files from your hard drive. If you are not sure where your music is located you can run a search by clicking START>SEARCH>FOR FILES OR FOLDERS (if you are running XP click pictures music or video, check music then click search, each file will have it's location in small print below it's name, or you can right click each song and hit copy, then go back to f: drive and right click and hit paste, you can copy more than one). Hope this helps.
on Jul 08, 2008 | SanDisk Sansa e250 MP3 Player
How can i format my e250 drive?
http://www.sansa.com/download
If it cant open on your computer change your usb settings from MTP to MSC and try connecting again.
Jul 18, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250...computer will not detect
If you are using a USB connector [that connects extra ports to your computer] it sometimes doesnt work... so if possible hook the USB sansa cable to the main ports in the back of the server. It might also work to hook it in, and then go to 'My Computer' and see if it shows up there. Good Luck =]
Jun 05, 2009 | SanDisk Sansa e250 MP3 Player
Just says connected until the battery dies.
first off if you can turn the player off
try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
if that doesnt fix your problem try this...
if you can actually connect your sansa to the comp. and see it in explorer try this....
1 connect your sansa to comp via usb cable
2 right click start on windows desktop go to explore
3 scroll down to your sansa's drive rifght click it go to properties
4 go to tools tab and click "check now" under error checking will take awhile and will erase your memory on the sansa but it will probably work again
I hope my post was helpful let me know!!!!
Mar 14, 2009 | SanDisk Sansa e250 MP3 Player
SANSA E250 IS NOT RECOGNISED
There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
Jan 28, 2009 | SanDisk Sansa e250 MP3 Player
I need help with my sansa e250..thnkx.!!
I think maybe it isnt connected to the computer corectly because it should go to the connected screen. try hooking it into the main USB ports.
Jan 17, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250 does not appear in Windows Media Player when connected
Go intothe Settings menu of the Sansa and change USB Mode from MTP mode to MSC mode or vice versa
Jan 11, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250 won't show up in devices!
I had the same issue. Brand new Sansa e250 player. My XP SP2 computer would not recognize it. I updated my Windows Media player to version 10. Bingo, all is working now. I previously had version 9. Good luck!
Dec 24, 2007 | SanDisk Sansa e250 MP3 Player
What to do if you deleted everything on a sansa e250 MP3 player
Connect the sansa to your comp.. it will be shown as a drive right?Well just right-clickand click format...Thats all..
Nov 07, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
