Question about E-Machines eMachines Desktop PC
  • Richard Finch May 11, 2010
    Why do you want to do a system restore?
    This is really important because I can recommend other things first.
  • 397 Answers
Click Start (bottom left of your screen), right click My Computer, in the drop down menu select properties. Whe the window opend in the top left tab, select System Restore.
Make sure the little "Turn Off System Restore" box is not checked.
What operating system are you using?
What version of Norton are you using? and is it a paid for version or a trial version?
Posted on Jul 23, 2008
Why does the engine light sometimes come on and car bogs at 2000 rpms a few days later the light goes off and the car drives fine.
you have a sensor or component going bad and every time you disconnect battery your resetting it but when computer cycles thru the bad part will set off the trouble light ---have the vehicle scanned for the code most auto places offer this service for free with the code you can fix the problem
Oct 01, 2016 | 2001 Chrysler PT Cruiser
I am unable to get my acer 3515 to load. It goes onto the windows startup screen, takes a long while then goes to a black screen. Ive tried to do system restore in safe mode but there are no restore...
Press ALT key and F10 at the same time when Acer logo comes up on the screen to attempt full recovery of the operational system to factory setting.
May 05, 2012 | Acer Computers & Internet
What happens if you reset
Reset What?
If you Reset a Router then it goes back to the settings set by the manufacturer. It will be just like it was when you first purchased it. You will have to reconfigure it to get on the internet.
If you do a System Restore it lets you return your system to a restore point (date and time) when you know your system was working properly. It does not lose any of your data, documents, music, pictures, videos or programs. If you installed a program after the restore point (date and time) that you selected, you will have to reinstall the program.
System Recovery WILL LOSE EVERYTHING. It sets your system back to the manufacturer's settings. It will be like the first time you purchased the system from the store. All of your data, documents, music, pictures, videos and programs will be gone.
Mar 23, 2012 | Computers & Internet
I am victim of software counterfeiting
if you purchased software w/ credit card / personal check or even money order it can be traced and a chance of refund. wired money not chance... cash to a store chain they will refer you to Microsoft itself... download from the internet (other than Microsoft) you are really playing in gasoline. (this could have been worst a virus)
so if you can reset the pc start/all prog/access/sysytem tools/system restore ... set it back 1 month prior to this problem
hopefully this helps
Aug 24, 2010 | Microsoft Windows XP Professional for PC
Restore will not work comp goes thru the motions and comes back with unable to restore, it doesn't matter how far back you go
Hi, I believe you need to reinstall your operating system, follow these instruction:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Jul 15, 2010 | Medion MD-1768 PC Desktop
Air bag shocks on 1998 Ford Expedition Eddie Bauer goes down.
check valve for pump is bad leaking back thru,that is if both bags are deflating
Feb 22, 2009 | 1998 Ford Expedition
Want to reset the factory settings
If the issue started happened after installing/uninstalling some driver/software, Then you can use the System Restore option offered by the Windows operating system. This will help you restore your computer's system files to an earlier point in time. It's a way to undo system changes to your computer without affecting your personal files, such as e‑mail, documents, or photos.
System Restore uses a feature called System Protection to regularly create and save restore points on your computer. These restore points contain information about registry settings and other system information that Windows uses.
Feb 01, 2009 | Computers & Internet
What antivirus and antispyware scanners do you have installed?
Is System Restore enabled?
Jul 23, 2008 | E-Machines eMachines Desktop PC
Unable to access restore-point feature
Try booting into safe mode and accessing it from there.
To get into safe mode, press F8 when you turn on your computer and keep pressing it until the menu appears from which you can select safe mode.
Jun 22, 2008 | Computers & Internet
Moved and new internet service now MS Office wants a product key`
The computer should have come with a document envelope that contains all the software that is pre-loaded (backup copies) along with the license sheets.
Jun 21, 2008 | Gateway GT5032 (827103078121) PC Desktop
E-Machines eMachines Desktop PC Logo
52 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
