Question about Maytag Dryers
I need instructions to install belt on my clothes dryer Model no.lde9304ace
    Master:
  • 382 Answers
Please check the following link for how install belt in your dryer..
http://repair2000.com/wpoolbelt.htm
Thank you...
Posted on Jul 23, 2008
  • Maytag Master
  • 19,396 Answers
    Genius:
  • 3,422 Answers
HI,
Please CLIcK HERE all the steps are given including pics to install a belt on your dryer.
Change belt on maytag model # LDE9304ace
This youtube video will show you step by step how to replace the belt
http://www.youtube.com/watch?v=6ufArteqWXk
As shown in the video the part# for the belt is Y312959 it could be purchased from your local appliance parts store or online at,
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
GENE
Sep 07, 2011 | Maytag Dryers
I just had the belt replaced on my "Maytag" Gas Clothes Dryer Model #DG608. The repair man installed the new belt with the smooth side toward the drum as per one set of instructions derived from...
Herman usualy the groove side goes toward the drum which means it rides on the pulley from the motor disconnect and lean backwards to get a visual
Apr 05, 2011 | Dryers
Dryer is making loud grinding noise when in use. The sound is more prominent when loaded. Model # LDE9304ACE, well over 10 yrs old. Is this noise my motor or my pulley?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 01, 2011 | Maytag Dryers
I have Kenmore dryer, which was running fine until the last load. The hot air is coming inside, but clothes are not drying since it was not turning around. I cleaned the vent, please let me know, what...
The problem is likely the dryer belt . Here is a video on replacing a dryer belt. It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Sep 19, 2010 | Kenmore 63942 Dryer
Step by step instructions on how to install clothes dryer belt
First you take the top off by opening the door. There are two screws in the top part. Second there are two screws that hold the front on, on both sides. You take them out. Finally, this is a important step, remember how the belt goes back on. The Idler controls the tension on the belt. Next after the tension is remove the drum out. Put the new belt around the drum and then around the motor pulley. Then move the idler to the right I think and the move the belt past the idler and that will gain your tension.
Nov 28, 2009 | GE Dryers
Where can I find a diagram of the belt and pully system for whirlpool electric dryer ler5636eq3
Check here and see if they have what you need.
Clothes Dryer manuals. Clothes Dryer user manuals. Clothes Dryer owners manuals. Clothes Dryer how-to instructions. Clothes Dryer help.
laundry.manualsonline.com/manuals/device/clothes_dryer.html
You can check here also: partsselect.com
I hope this helps you.
Oct 03, 2009 | Whirlpool LER5636P Electric Dryer
Hello I have a Kenmore clothes dryer (80 series) and it having a problem,the motor is working and the heat is coming in the dryer but the part where the clothes go to get dry is not turning ,what could be...
Hi, Sounds like the belt has broke. These instructions fit most models. If they do not apply to you dryer model, please get me you model # and I can give you exact instructions. UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
There should be instructions that came with the belt. I will try and explain how this goes on. The idler pulley fits in a slot right in front of the motor. Put the belt over the drum with ribs touching drum. Now, thread the belt through the idler pulley wheel and bracket and set the belt on the motor pulley. The ribs should rest in the grooves on the motor pulley.
I hope this helps you. If I can assist you further, please let me know. Please rate me performance so that others as well as myself will know how I am doing.
Thanks
Sep 13, 2009 | Dryers
Dryer drum does not turn
Most likely the belt broke, replace the belt
Aug 14, 2009 | Dryers
My maytag (#LDE9304ACE) sounds like a popcorn machine
has the blower wheel rounded out in the center motor shaft area .give that a check.it has fin's and about 10'' to 12'' in diamitter.other wise check rollers and glides.if dryer drum was oblong that would create a noise as it tumbled.you are welcome to email if needing more help. God bless ,tom
Jan 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Need to replace the belt on a moffat clothes dryer, model md777lw449
I took the model number of the dryer to a supplier (Amre supply Hamilton On), they sold me the belt. I found replacment instructions on the web and did the job myself.
Nov 20, 2008 | Dryers
Dryers Logo
539 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
