Back to:
Tags:
Epson Aculaser C1100 Printer
Service req. c0090 error code
posted by donnaparker on Jul 23, 2008
i have had the printer unplugged for about 3 months i hav just replugged it in and this code has come up. i cannot find anything online can you help pls.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 18, 2008
Not Rated (0)
Benimur
Rank:Guru Guru
Rating: 87%, 2403 votes
Might be something mechanical, stuck or jammed. Perhaps a copy of the parts diagram and/or the multi part service manual might be of more help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on service req. c0090 error code:
I don't want to Accept this solution
Can you Help with these Printers problems?
When I try to print through the network it says...
Hi, I'm getting a message 'Service Required C0085' can...
Hi! I have a canon (1800) super G3 printer, it reads:...
The printer will not operate and states that "B...
Hello, I have problems to install an Aculaser C1100...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
