Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Tv Problem The tv comes on but the screen just stays black and sometimes the screen will blink really fast in the colors of blue and green but most of the time the screen stays black and there is no picture at all i replaced bulb with new bulb same thing happens, also there is a little red light that comes on that says bulb what is the problem with this tv shouldn't it last alot longer. i mean it's only four years old.
    Problem Solver:
  • 9 Answers
Check the circuit board for possible loose connection,try to resolder the horizontal circuit and the crt board.
Posted on Jul 24, 2008
Why does my KD-32FS170 32" Sony Trinitron screen have blue hues
If you turn all of the color out of the TV, the picture should be black and white. If that picture is not a true black and white picture, the TV will produce a color picture that has that behind it. It takes the proper mixture of red, green and blue light to produce white. This is something that is done inside the glass picture tube.
In your case, one color (blue is stronger) and the others are weaker.
It probably had not been used for a while. SOMETIMES, the weaker colors will get stronger with use. Adjust the brightness and picture controls to get the closest you can to a black and white picture, and then add the amount of color that seems right to you. Use the TV and hope for the best. It will improve, but 2%, 10%, or 50%; I do not know. The proper repair is to replace the glass picture tube, which is not an option at this time. So, turn it on, play games, and HOPE for the best.
Dec 04, 2014 | Sony Televison & Video
Sony KDL46V2000 TV. Screen comes on and goes off in continuous cycle
you have a leaking cap on your power supply /open up and check on just replace those caps that looks swollen
Nov 16, 2017 | Sony KDL-46V2000 46 in. LCD Television
Hi i have a kp-57HW40 sony projection tv. Right now it is failing, and when I turn it on I hear multiple clicks. The screen will not even light up, just stays black as it if were powered off. On the...
Thats the error for having a issue with the +5V which can be caused by either the A board or the B Board with the B board being the most likliest cause.
Jul 09, 2011 | Sony KP-57HW40 57" Rear Projection...
MY HD56FN97 JVC 56 inch tv. I was just watching it and it went black. Now it wont turn on the blue light flashes really fast and the screen is black. WHat is the issue here?
Count the number of blinks and the sequence. Google your make and model with blink codes added to the end. This will guide you to links that will tell you what the blink code means and what is wrong with your tv.
May 15, 2011 | Televison & Video
When i plug in my tv the screen stays black and wont come on
Hi my name is Roety,
I can help you with your issue ,
Your Mittsubishi has a system the will cause the green light to blink for 70 seconds when first plugged in, if the green light never stops blinking it is either a power supply issue or a stuck keyboard button.
So do the test and reset it to see if the light stops blinking or not.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Apr 15, 2010 | Televison & Video
Panasonic multimedia projection HDGT tv color spots displayed
PANASONIC..PT-52LCX15. STARTED TO A LIGHT COMES ON THE SCREEN. THEN TWO LIGHTS. FINALLY TV DONT COMES ON. I PUT ON THE TV, AND ON BOTTON START BLINKING AND TV DONT COME ON..I TAKE OUT THE TV LAMP..IT LOOKS GOOD NOT BURN. SHOULD I REPLACE IT??
Oct 18, 2009 | Panasonic Televison & Video
Bright Blue and Green screens seem to blink.
Do not use component video. Test S video or 3 rca's red black and yellow(video) , see if they work! you need all 3 inputs on component video, sounds like you may have the colors mixed, check all color coding slowly. Sometimes the comp video out can be too strong, try using a splitter , reduces signal by 3 db, try 2 then 3 in line. This is only a test. keep in touch...
Please rate!
Mar 31, 2009 | Televison & Video
Mitsubishi wd 52525 Problems, but no blinking lights.
Are you using an hdmi cord or av cables?
Apr 10, 2017 | Televison & Video
SAMSUNG DLP TV HLR5067W
The main board is more than likely the cause of the trouble. Time for a new TV.
Oct 29, 2017 | Samsung DLP HL-P4663W 46" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
