Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer door I have a front load dryer by Frigidaire that is 2 years old....We switched the door and then it would not stay shut. Then we called the gas company since we have service guard and they put on a door part and it still won't stay what ?
  • 639 Answers
ngfam1 here for you!
I am happy to be of assistance!
Now the gas company fies many types of appliances A.
And Frigidaire only fixes Frigidaire Appliances!
I think the gas company wastes our money !!!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
Posted on Aug 28, 2008
Front load frigidaire one year old and cycle won't start from one day to the next. The panel lights are indicating things are correct but the door lock light does not go on when I press start and the start...
I have had to change the door switch on every washer and drier I have ever had. Just a thought: If the door switch is bad the drier and washer will not start working. The one I changed on my drier about a month ago, when I opened the door and played with the switch while pushing the start button it finally came on. I changed the switch and no more problems. If the door is open the dryer and washer are not supposed to operate. I have changed some which you could not move around on those I would pull the wires off the door switch. Depending on if the switch is normally open or closed I would connect the two wire and try to start or leave them separate and try to start..
Nov 19, 2017 | Frigidaire GLTR1670A Front Load Washer
Frig. gas dryer agq6000es not tumbling
Do you hear the motor running? With door closed.
Most dryers will spin though a little hard to do so. If it spins VERY easy the belt is possibly broken.
If the dryer is several years old it Could be the belt.
Also check for a switch for the door, if there is one.
Door switch would shut off dryer when opened.
Nov 29, 2013 | Frigidaire AGQ6000ES Gas Dryer
Frigidaire Affinity gas dryer problem
I would bet you need new door lock switch
Jul 13, 2017 | Frigidaire Dryers
(2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Feb 21, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Hello, I have a frigidaire washer. I loaded it up and started it - the water went in. But after that, it just stopped. I tried it again, tried different cycles, still doesn,t work. The Start light is...
Well I'm not an expert but I have had problems in the past but it was with my top loader washer. Sounds like it could be a number of things: could be the transmission, or could be a switch or an electrical problem (thats the problem with these new digital washers/dryers!). You will definitely have to call a technician unless you can get a manual and try to fix it yourself. Mine is a year old and I purchased some extra insurance for it, like a year or 2 worth when I bought my washer & dryer new. If your washer is less than a year old you can probably get the manufacturer to fix it for free! Good luck!
May 15, 2010 | Frigidaire GLTF1670A Front Load Washer
My frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
High efficency dryer won't spin-Frigidaire
Try this. Set the timer. Open the door, press and hold the light switch. Rotate the drum by hand then while still holding the light switch turn on the dryer. If it starts then clos the door while removing your finger quickly. If this problem persists it could be the starter on your motor.
Mar 22, 2009 | Frigidaire FEQ332E Electric Dryer
Frigidaire Gas Dryer - Heats for 1-2 minutes then gas shuts off
Most of the time, the culprit is a bad gas valve coil(s). Replace those, and your dryer should return to normal operation.
Aug 14, 2008 | Frigidaire FGR231A Gas Dryer
Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
May 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLEQ2152ES Electric Dryer Logo
85 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
