Question about Sony Playstation 3 (PS3) Console
Playstation 3 i can plug my PS3 up and tell that there is power running to it but whenever i actually turn on the ps3 it starts making a very irritating, and what sounds to be damaging, clicking noise. if i just plug it up and gpress the eject button all it does is beep as in its been rebooted, but nothing has happened. it wont eject the disk and wont come on for me to do anything else with it. what do i need to do?
  • 344 Answers
As for the disc, you have a slipped gear in the BR drive. It sees the disc is there and it's trying to eject it, but one of the side arms inside isn't aligned with the gears. I suggest calling Sony first, if they will not fix it then find and contact a pro. I hope this helps. Good luck.
Posted on Jul 26, 2008
Tip
How to use a ps3 wireless controller.
<span>Ensure your playstation 3 is properly set up and connected to Plug the power cord for the PS3 wireless controller into one of the usb ports on the front of the PlayStation 3.<span><br /><br /></span><span>Plug the power cord for the PS3 wireless controller into one of the USB ports on the front of the PlayStation 3.<span><br />Plug the other end of the power cord into the access port on the top of your wireless controller.Allow the wireless controller to charge, leaving it plugged into the PlayStation 3 undisturbed for several hours to gain a full charge.Disconnect the PS3 wireless controller from the power cord. Press the PS button to start up the PlayStation 3. The PS button is in the middle of the controller. It is clear and displays the PlayStation logo of a letter P and a letter S molded together into one shape.Use the wireless controller to control the PlayStation 3, exactly as you would have with a corded controller for earlier PlayStations.<br /><span><br /><br /></span></span></span></span>
on Dec 06, 2010 | Sony Playstation 3 (PS3) Console
What is the proper pairing procedure?
When you're attempting to pair them, are they physically attached to your PS3 using the charging cord? Whenever I paired a headset, I'd plug the charging cord into the headset and into the PS3 and then turn on the PS3.
Sep 17, 2014 | Sony Playstation 3 (PS3) Console
PS3 Controller Keeps Flashing
Does the controller actually turn on and if not you have to connect it to the ps3 or whatever your connecting it to
Oct 16, 2013 | Sony PS3 DualShock3 Wireless Controller...
Went on vacation and left the PS3 powercord unplugged. Now it doesn't work, could it be the cable?
Hey there, a couple of things to verify here to get your ps3 back up and running. Do not worry about leaving your ps3 the whole week with the powercord unplugged, this is OK and should't have affected anything negatively.
1) Make sure that the powercord is well plugged on both ends: ps3 AND in the wall.
2) Make sure that the SWITCH is turned on (in the back of the ps3, there is also a POWER switch I/O). Turn it on by pushing on the I.
3) If it's still unpowered, try plugging the ps3 itself somewhere else in the house (to make sure it's not the power outlet)
Jun 23, 2011 | Sony Playstation 3 (PS3) Console
My ps3 turns black and nothing happens
Try checking your HDMI or VGA lead and reset the Ps3 Settings
Oct 03, 2009 | Sony Playstation 3 (PS3) Console
Disk not reading
I had a similar problem. My PS3 was not starting the game discs when I inserted those to PS3. Also those game discs were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 17, 2009 | Sony Playstation 3 (PS3) Console
Problem with playstation 3 games and blue-ray
definitely a prob with the blueray laser u need to bring it back to shop or sony as there is no way u can fix it yourself.
Jan 02, 2009 | Sony Playstation 3 (PS3) Console
No pickture on my ps3
Okay, I am now going through all the unsolved problems for which previously I had the same problems and now posting our solution. First, if you have no pic due to swiching of the cables (ie, cable av, hdmi) WHENEVER you switch your cable output, the ps3 also switches it's output. Make sure when there is no picture due to this problem to turn off the game console, then turn on, hold down the power button for approx. 5 SECs, there will be a BEEP. Let go of power button, the ps3 has then switched back to the output it is currently plugged in and will work. (ALSO sometimes you have to have ONLY the ps3 and tv hooked up) Hope this helped. I know how stressful this can be!
Nov 12, 2007 | Sony Playstation 3 (PS3) Console
Can't get connected to my cable connection
Oct 04, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
99 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
