Question about Maytag MFI2568AE Side by Side French Door Refrigerator
Refrigerator not working properly
Lights flashing on panel and popping noise from ice paddle
  • 4sierras Jul 24, 2008
    thanks you guys are great!
  • litewave_fl Jul 24, 2008
    Panel lights flashing, ice door flapping and no ice or water dispensed. This is a problem with this model of Maytag refrig. since they have been making it. I have never been contacted by Maytag of a recall and mine is 1 year old. Glad I bought the extended warranty. I would fix the circuit card myself if it wasn't in warrnty. I may still if they take too long to replace it.
  • 93 Answers
Dispenser board needs to be replaced. There was a recall on certain Ice 2O units. Call Maytag and see if your unit qualifies.You will need model and serial number.
Posted on Jul 23, 2008
  • Edward OConnell Jul 23, 2008
    Part number for board 67006294
Frigidaire Gallery series ice dispencer does not dispence ice. Also, what is proper freezer setting?
Thank you for your inquiry, friend!
Based off what you have described you are having trouble with your ice dispenser not dispensing inside of your Frigidaire refrigerator and you would like to know the proper temperature setting. You may want to open the door of your freezer and check your chute to assure that there are no ice chunks or frost causing issues with your ice dispensing. When you push on the paddle do you hear a noise? If you do not hear a noise your auger could be bas inside of your icemaker. If you hear a noise and no pushing it could be a possible problem with the motor. It is recommended to have your freezer on a zero degrees for a factory setting. I hope this information is helpful. If you need any further assistance please feel free to reconnect. -Matt
Feb 21, 2015 | Frigidaire Refrigerators
Just bought a used westinghouse RJ275M fridge. It seems to work fine except for the noise - it has a low hum and rattling noise.
It can be compressor fan noise,may be motor getting overheated and causing noise.It has to be inspected.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
How do i remove the ice shoot on my ge profile model# pfss6pkw
pop the control panel off by taking a thin blade knife at the bottom of this panel and prying out on the two edged of it,then unplug the wire harnesses to it,then remove 4 phillips screws behind it remove the paddle assembly,dont lose the little spring on the paddle
Nov 04, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE ICE MAKER, VERY LITTLE ICE,
I had this problem with my GE ice maker not working and it was an unbelievably easy fix. If you have the same ice maker then you will see a green light by the power switch. Below the ice maker is a "paddle" ice sensor. The paddle is attached to the ice maker and there is a coil type tension spring. If your paddle is loose, make sure the end of the spring (the pointy wire end) is inserted into a small hole. You probably can't see the hole but move the wire end until it pops into the small hole. You should now have tension on the paddle. At this point I had heard that the freezer light bulb may be drawing too much current for the ice makers motherboard. I removed the bulb and, UNBELIEVABLY, the ice maker began making ice! Try removing or replacing the LIGHT BULB first!
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool gold side by side 2006 defrosting
temperature gadge must have been bumped, everything is working right now. Thanks
Jun 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hotpoint side by side noise
Have you made sure that the ice tray/box is inserted correctly? By lifting up and inserting the box until it goes in all the way. Also, check the ice chute from the inside and look for any obstruction such as ice formed/melted causing the blockage. Once you correctly insert the ice tray back in, try the ice button to reset the paddle drive. Also, these icemakers are slow to deliver when the ice bin is low in ice. FYI, if you stack too much frozen goods underneath the area below the ice tray, the paddle drive mechanism will sometimes come into contact with the food packaging. The wrapping from the packages can get caught under the paddle drive and creat a problem by slowing it down. Check and clear it. Be sure to unplug the refrigerator before you do this. Let me know if this helped.
Oct 28, 2008 | Hotpoint HSS25GFP Side by Side...
Maytag MFI2568AE Side by Side French Door Refrigerator Logo
201 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
