Question about LG Prada KE850 Cellular Phone
LG Prada KE850 Date Setting Problem
When i set the date on the phone it is fine for a bit but then rests to the day before whats the problem?
  • danooa Aug 01, 2008
    i have same date problem please tell me any solution for that or i possible any software fix
    thanks
    aazad a danoo
Ive had the same problem...its really annoying..i tried everything and the thing that seems to work is...say today is the 6th and on ur phone it says its the 5th ...set the date to the 7th and it should be ok since it always comes up 1 day behind...hope this helps !! :) ......as cool as it is the lg prada is sooo retarded!!!
who would of thought ...u spend a load of money on this really smart looking phone and it ends up doing something like that...something so simple but soooo annoying lol anyways cyaaaaa good luck!
Posted on Aug 06, 2008
Hi i´ve the same problem, i don´t have the fix but if you change the "Time Format" to 12-hour and set again the date, that´s don´t change ... I hoppe this tip help us
cheers from Mexico
rpega82@gmail.com
Posted on Aug 01, 2008
I've seen several posts on this and htink its still just a software fault..
If you turn Auto Update on and then turn your phone off straight away without setting hte date the problem "should" be fixed,, not sure about htis as my date changed back after a week....
If you get any more slutoins to this please let mek now a jonmayes@live.co.uk
Cheers
Posted on Jul 28, 2008
My phone lg prada sb310 not detect network
Check LG site for directions how to factory reset it. Usually it is a combination of power and/or Vol+/-
Aug 29, 2017 | LG Prada KE850 Cellular Phone
Tip
LG KE850 Prada Unlock Code
Does your LG KE850 Prada work only with your current service provider or, when you insert a SIM card from another network, do you see any of the following messages?
  • Enter Subsidy Code
  • Enter Subsidy Password
  • Enter SIM Unlock Code (Simlock)
  • Contact Service Provider
  • Insert Correct SIM Card
  • Wrong SIM Card
  • Incorrect SIM Card
  • Phone Restricted
  • Can't Undo Restriction
  • Locked Return For Service
  • Enter Unlock Code
  • Enter Special Code
If so, your LG KE850 Prada is LOCKED and we can help you remove this lock on your LG KE850 Prada in a few simple steps, allowing you to use your phone on any GSM wireless network anywhere in the world.
You will not have to mail in your LG KE850 Prada. No Hardware or Software required. No technical knowledge required at all. Simply provide us your LG KE850 Prada’s IMEI number and we do all the rest.
Three Simple Steps
  1. Simply provide us your LG KE850 Prada’s IMEI (which can be found by typing *#06# into your phone), during check out.
  2. After order placement, the Unlock CODES together with easy to follow instructions guides will be sent to your email address within the time frame given.
  3. Follow the unlocking instructions provided by
    Reasons to remote unlock your cell phone
    • Save a fortune abroad, by using cheap local SIM Cards rather than expensive roaming tariffs.
    • As usually subsidize the cost of the phone, by unlocking it you are increasing the resale value of your LG KE850 Prada by up to 300%.
    • Use your work and personal SIM Card in your unlocked LG KE850 Prada - no need to carry two phones again.
    • Get the best value tariffs by swapping SIM Cards to take advantage of the latest offers.
    • You never send your phone to anybody.
    • Fast and easy. You receive the instructions within hours; unlocking itself takes 1-3 minutes.
    • No opening your LG KE850 Prada and risk of damage to your device.
    • Very easy, no technical experience necessary.
    • No complicated software or hardware just enters Unlock CODE, and your LG KE850 Prada is PERMANENTLY unlocked.
    • Is safe and does not void cell phone's warranty.
    • Unlocking is a one-time event. It works for the life of your LG KE850 Prada.
    Warranty
    All our Unlock CODES are 100% genuine and guaranteed, if for any reason your unlock codes are not found in our database then we will issue a full refund.
Instructions Unlocking Instructions for LG KE850 Prada
How to insert the Unlock CODE into your LG KE850 Prada
  1. Insert a not accepted SIM Card and turn ON your LG KE850 Prada.
  2. Your LG KE850 Prada will display "phone restricted".
  3. Select Cancel
  4. Your LG KE850 Prada will display "phone restriction code".
  5. Enter the Unlock CODE you received from UnlockallCellular.com
  6. Select OK
  7. Your LG KE850 Prada is now unlocked!
on Apr 07, 2010 | Cell Phones
KE850CP40-7-V10i-JAN-19-2008 solve Deat Problem. But how to use it?
To enable the connection between the pc software and your phone, you need to first go to settings on the KE850, Connectivity (scroll down to see this option), USB Connection - and change this setting to Data Service. For simple upload of files, eg. mp3 or jpg, set this option to mass storage.
Apr 19, 2008 | LG Prada KE850 Cellular Phone
The date keeps going back!
There was another series of messages about this one...it happened to my prada as well. Go into the Settings > Date and Time > Auto Update....
Set Auto Update to ON
Power down the phone....(Cancel phone call button for 3-4 seconds)
Boot it back up (make phone call button for 3-4 seconds)
Problem should be resolved! Just did this to mine about 5 minutes ago, so not sure if it works, but others have said it does.
*Shakes fist at Prada* :P
ps...gorgeous phone tho...hehe...and very popular with the ladies ;P
Mar 26, 2008 | LG Prada KE850 Cellular Phone
LG Prada Phone issues
If you have warranty on it send it in. If you buy it from a non-authorize party, you might got a factory defect, refurbished Chinese knock off.
Mar 06, 2008 | LG Prada KE850 Cellular Phone
Mobile phones
yeah tht is a bit of a prob. one way to eliminate tht is by using the 24hr clock. having set it to 24hr mode i found eliminated the prob.
but again the phone does have a bug with the date changing back and lg needs to address it.
Feb 26, 2008 | LG Prada KE850 Cellular Phone
Where to download software update for the Prada?
Unfortunately to flash the LG Prada, you will need special hardware. It's not as easy like with flashing Nokia and Sony Ericsson phones. Regarding the date bug...it is a very common problem. Try clearing all the alarms if you have any set.
Feb 22, 2008 | LG Prada KE850 Cellular Phone
Wrong Date/Permanent Message Envelope
i got in touch with tmobile about this problem with my phone and they told me to take battery out and sim card to reset it and so far its working hope his helps
Jan 24, 2008 | LG Prada KE850 Cellular Phone
Date Changing
you shud try change settings so that date and time will auto update. this is under settings, date & time, auto update....mite work!
Jan 10, 2008 | LG Prada KE850 Cellular Phone
Date not changing on mobile phone
Hi i had the same problem
wot i did was change the date to a day forward say the 10th of jan
and then it automatically started working after tht
(previously it was going back a day so i just used the date of the next date and left it like tht and it has been ok since then)
Jan 03, 2008 | LG Prada KE850 Cellular Phone
LG Prada KE850 Cellular Phone Logo
116 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
