n wista also huawei driver works,,i too tried to install wista drivers
for huawei but in vain ..no problem in xp driver itself it will
work,,,if it works mail me at aravindterror@gmail.com and don't worry
it will work conformly because now im using ny connection in wista
using huawei only.. just follow the step to do it: 1)install that driver setup and warning the usb port from modem should be disconnected during this 2)install will finish and wait's for usb port to be connected by displaying port not found, 3)now
plug the usb cable and inbuilt windows will appear and say found new
hardware and install from the location where you had whether from cd or
from hard drive,select appropriate option.4)if it says error during
installation , 4)goto my computer right click and select properties
and select device manager in that under other devices categorie you
will found your device with question mark,right click that and select
update driver and selec from the location where you have that driver
back up i.e from cd of location in hard disk..then it will finish
installing software and once again it wil ask if automatically it
finishes secon time installation no problem or else follow from step 4) 5)now your usb will be identified by your huawei installation process and say port found click next and it will finish setup 6)then
once again goto my computer and then right click and than goto
properties and device manager and right click on your name at beggining
then select scan for hardware changes,,that's all finishes.. 7)select
connect to from your wista and select new connection and select connect
to internet in that dialup ,enter your dial up phone no,username and
password..then it will connect....ha ha.. if it works mail me at aravindterror@gmail.com
will vmmi version 17.11.06 D work for programing from my laptop on a FXII. I am worried there is a...
(More)
will vmmi version 17.11.06 D work for programing from my laptop on a FXII. I am worried there is a newer version that I need for this to work.
I have a Canon MF6550 and it has been great until now. We recently switched from analog lines to...
(More)
I have a Canon MF6550 and it has been great until now. We recently switched from analog lines to intergrated T1 with a PRI(23B+D). Now our fax will receive but not send faxes. Any suggestion as to what settings I could change for fix the problem?
my modem will no longer recieve faxes it says a fatal error has occured but it will still send faxes...
(More)
MY MODEM WILL NO LONGER RECIEVE FAXES IT SAYS A FATAL ERROR HAS OCCURED BUT IT WILL STILL SEND FAXES FINE. I AM USING WINDOWS FAX CONSUL ENABLE SEND AND RECIEVE ARE CHECKED
hi i have a sb5101 that has haxoware in got it done last week now have 2 lights on how do i get into...
(More)
hi i have a sb5101 that has haxoware in got it done last week now have 2 lights on how do i get into it to change firmware a friend done it for me but he is in scotland am in liverpool
