Xerox Phaser 6100/BD Laser Printer Logo
Posted on Feb 11, 2011
I have a xerox 6100 printer and when i print it prints the document onto 2 pieces of paper. The first page has a 2 inch margin at the top and no margins have been set. I can not seem to get this problem fixed. Please help!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
105
Points
I was having a problem like that on the right and did a firmware update and reset the printer, now it's fine.
I am printing on 8 1/2 by 14 paper landscape. The document is not covering the entire paper.
Do you want the document to fill the page from corner to corner? You won't be able to do that due to the margin settings. The printer needs to be able to pull the page through the machine without touching the ink, so it can't print on every available inch of the page. You can minimize the margins as much as your printer will allow under the Page Settings menu, but it will always shrink the document to fit within the margins on the page.
Hope this helps!
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
I am a teacher. We have Dell computers with windows 7 on them. Recently our school district downloaded Microsoft Office 10. Since the new microsoft office, my xerox phaser 8500 is printing strange. ...
Hi fsaltzman,
You need to check the margin settings in the print preview option, make sure you decrease the margins that are set by default and try printing a test page , this should work fine.
On the File menu, you need to click Page Setup, and then click the Margins tab.
Here you can adjust the margins as per your convenience.
To View page margins :-
  1. You need to go on the Tools menu, select Options, and then select the View tab.
  2. Under Print and Web Layout options, select the Text boundaries check box.
The page margins appear in your document as dotted lines.
You can use these dotted lines to correct your margins so that your student's assignments are not cut off and there is no large margin as you have mentioned in your question.
You can view page margins in either Print Layout or Web Layout view only, and they do not appear on the printed page.
Hope this helps
It will not print Word documents. it pulls a blank piece of paper through. It will print in notepad
there is something wrong with your Word printer setup. Go to Word, then from the File menu select the Print option and when the print window opens see if the HP deskjet is selected as default printer. Then, in the upper right quadrant theres a button called Advanced Settings, or Prefferences (depending on your Word version). Click that button and check to see if the HP printer is set as On Line, and is set to print odd and even pages. Also, check the margins of the paper. Ink Jet printers cant print over the full page, there's always a need of some margin on each side of the paper, so you'll need to set the margins from all sides on at least 0.5 inches
I am trying to print onto pre-printed forms which have a dark blue band at the top. My printer isn't recognising that the band is there so is starting to print too far down the page. Help please!
This type of problem can usually be resolved simply by adjusting the margins from within your word processing program. Depending on which word processor you are using you can go into the page setup and make these changes. For Microsoft Word go to the "File" tab at the top then to page setup. The first tab that comes up will allow you to change the margins on the page. If the print is too far down try reducing the top margin from one inch to 0.5. If that is not enough reduce it some more. Print test pages on regular paper, then hold them up to the light against the paper with the pre-printed band to see how the print lines up. That way you don't waste the expensive paper!
The printer is feeding a blank sheet of paper between printed sheets. How do I rectify this?
This causes the printable area on the page to be that much less (10 3/4 or 10 1/2 on an 11 inch page). The software thinks the paper is 11 inches long and keeps track, down to the micro inch, where it is on the paper. When it reaches the 10 1/2 inches, your printer calls the page done and ejects it. However, the software thinks there is still another 1/2 inch to print (usually the footer area). Now when you insert a new sheet of paper, the software finishes printing the rest of the page (normally a blank footer) and form feeds to the next sheet. To correct what the software thinks the paper size is, you need to run the Preferences application and change the default settings. Select the Printer button. In the next window, select the 'Change Defaults....' button. Change both the Document size and the Paper size to a height of 10.875 and click OK. Try a new document to see if the paper size is correct. You may need to go back and change the height a few times until it is correct (the height changes in .125 increments). Usually either 10.875 (for 1/4 inch forced top margin printers) or 10.75 ( for 1/2 inch forced top margin printers) will work.
2answers
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
2answers
TALLY T2250 PRINTER
It sounds like there is 12 inch form length (or may be A4) selected on the computer system. The data from the system will take precidence over the 11 form length set on the printer.
If using Windows, ensure the Printing Preferences in the pritner driver are set to 11 form, Also check Printer Properties for a paper size ensure this is set to 11 inch
On the 'System' check the paper size selected within the application (if available) Check this is set to 11 inch form length
Check document margins to ensure these are not reducing the 'printable area' on the page. If availabe to a Print Preview on system to see what the document looks like.
If your application outputs raw data to the printer, check the number of lines per page assming printing at 6 lines per inch you can fit 66 lines on an 11 form. Check no more than 66 lines are per page, it sounds like 72 might be being sent befor a Form Feed in the data. (there may be a 1 line top margin set on the printer)
Finaly check the top margin setting on the printer to ensure it is set to 0 so you have the full 66 lines available on a page on the printer I think you would be looking to set the FORM ADJUST to 0 to adjust the top margin
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
